looking to go to the scrap yard 2mo but would like to know which car to take a
pedal box and master cylinder from
thanks in advance
[Edited on 15/8/09 by greed1]
What are you building?
Could you not make your own pedals?
locost 7
i cant weld so want to get a box complete
In that case then you can get a complete pedal box from an old mini.
cool thanks
i think i saw a mini last time i was there
cool thanks
what about the brake master cylinder
For the master cylinder you could put the pushrod somewhere along the pedal and use a sierra cylinder.
Easier option would be to buy an off the shelf solution if you don't want to weld one up.
Shaun
yes but that cost money
thanks for your help
couldnt find that mini so i gave up
looks like i will be buying a new one after all
what is normally used in a locost floor or top mounted
which do you suggest
thanks
Try here, a floor mounted one is easier I reckon
http://www.rallydesign.co.uk/index.php?cPath=562_580_581
