I need to get a fitting for my fuel tank and I am unsure where to get it from and what to get to be honest. The (part built) kit came with this
with this inside the tank
I assume from info gleaned off locostbuilders that its a high pressure fuel pump and return assembly. I need to replace this with just a pickup for
the fuel that would lead into my Facet Red Top fuel pump and then onto my Rover V8. Is this hole in the fuel tank with the six holes a standard
fitting
If so where could I get one from and what is it called?
Thanks for the help
Seasons Greetings!!!
I would just remove the pump from the inside (should be on with a length of hose), and replace it with a tube or hose that runs to the bottom of the tank. Will allow you to retain the entire assembly as just a pick up ??
Stupidly I didn't think of that. I shall have a look and see if thats possible.
