Hi everyone,
Sierra or Escort?
Thanks!
[Edited on 26/8/13 by sky]
Definitely Sierra! With a RAW insert for the strut hole.
Perfect, thanks!
Who did the welding on them wing stays
I hope the chssis is welded better then them
Not me
Hi everyone,
I would like to swap my Sierra's uprights to the rallydesign alloy types but they'are the Cortina version. The question is: can I use on a
Raw Striker Cortina's RD uprights with my wishbones without modifying something?
[Edited on 14/10/13 by sky]
Basically no, IIRC al the geometry and possibly ball joints/etc are different.
However Raw do Capri based uprights which i think share some Cortina components and are similar geometry, I expect you could proabably swap to
wishbones that suit those.
Best option is speak to Martin at Raw, he'll set you straight.
Thank you.
Hoping the Capri uprights are lighter and have better geometry otherwise I haven't any advantages swapping it.
Originally posted by sky
Thank you.
