jamesbaa
| posted on 18/8/09 at 07:14 PM |
sierra estate
Can a sierra estate be used as a donor? Iv seen one on ebay that looks alright and isnt to far from me!
mookaloid
| posted on 18/8/09 at 07:16 PM |
yep
jamesbaa
| posted on 18/8/09 at 07:19 PM |
is there anythink i wouldnt be able to use, For example i know a lot cant be used from the 4x4
handyandy
| posted on 18/8/09 at 07:24 PM |
my donor was a sierra estate 1.8cvh,
not much of a power engine but it,ll get me thru IVA as engine number matches the donor vehicle docs, maybe swap to zetec in the future as exhaust
exits on the same side
andy
blakep82
| posted on 18/8/09 at 07:26 PM |
can't use the prop. but i'd recommend getting a new single piece one made anyway
________________________
jamesbaa
| posted on 18/8/09 at 07:35 PM |
cool thanks guy's engine will be no good anyway as i plan on going BEC
avagolen
| posted on 18/8/09 at 08:15 PM |
Hi Andy,
I too am going the 1.8CVH / upgrade route.
What / How are you going to fuel the engine? Bike carbs or webers etc?
Len.
blakep82
| posted on 18/8/09 at 11:23 PM |
is it a diesel by any chance?
jamesbaa
| posted on 19/8/09 at 07:15 PM |
no it isnt a diesel, can i assume that a deisel sierra would be a ok donor if not using the engine!
bob
| posted on 19/8/09 at 07:25 PM |
Diesels give you that hens teeth wanted diff which some BEC boys pay good money for
What steering rack do you need for the indy R james ?
The old indy used a sierra manual rack which MK then modify,which is an exchange item when collecting your kit.
Power steering rack is of no use.
bob
| posted on 19/8/09 at 07:28 PM |
Diff codes
diff codes link
Mark Allanson
| posted on 19/8/09 at 08:08 PM |
Only the 2.3 Peugeot engined sierra has the low diff, the 1.8 TD has the usual 3.92:1
MautoK
| posted on 23/8/09 at 09:56 PM |
My donor was an 89F 2L Auto Estate.
MK took its prop OK in part-ex for the shortened one (non-standard because of the autobox being longer)
The diff is 3.38 (I think - still not done a wheel/prop rev count)
John.
col
| posted on 9/9/09 at 06:33 PM |
Mine was a 89 estate, with a 3.62 diff runnin a pinto ,has it still got the tag on diff housing?
