stuleah
| posted on 15/12/10 at 08:55 AM |
Sierra hub info
Can anyone tell me if all the sierra hubs are the same except the cozzie ones?
marcjagman
| posted on 15/12/10 at 09:09 AM |
4wd front are different as they have a CV joint. Otherwise all pretty much the same.
mcerd1
| posted on 15/12/10 at 09:11 AM |
these are the ones I know of:
front hubs
std. sierra (with or without ABS sensor hole)
2wd cossie - bigger than std. one
4x4 sierra
4x4 cossie
rear hubs
std. sierra with drums
std. sierra with discs
2wd cossie
4x4 cossie (I think these are almost the same as std. sierra's with discs, but the caliper lugs suit bigger discs)
granada rear hubs are 5 stud versions of the std. sierra with rear discs
granada cossie 24v rear hubs are 5 stud versions of the cossie 4x4 ones
(scorpio's are the same but 4 stud)
granada / scorpio front hubs are different to any of the sierra ones
[Edited on 15/12/2010 by mcerd1]
Dan.
| posted on 15/12/10 at 05:03 PM |
front hubs
4x4 sierra
4x4 cossie
rear hubs
2wd cossie
What he said, however 2WD Cossie's have 2 different types of knuckles/ Uprights one has pinch bolt lower mount one has a tapered mount, much
rarer (RS500 2WD Hatch) . Not sure if tere is a difference in the hubs them selves but thought it worth mentioning.
stuleah
| posted on 15/12/10 at 10:00 PM |
cool thanks for the info
dnmalc
| posted on 20/12/10 at 12:46 PM |
Note on the rear there are two sizes of drums
DixieTheKid
| posted on 13/2/11 at 12:42 PM |
Does any one know if Scorpio 24v Cosworth drive shafts and the same length as the Sierra's?
COS IT'S Worth IT
