timnuttuk
| posted on 23/3/15 at 01:38 PM |
Sierra wheels
Hi,
It's been a while since I posted on this forum. Sold my seven a few year ago now and started to build a Cobra... well 3 years on and I'm
finished and have 1 thing to fix on the IVA failure list. The issue is around self-centring -oh yes that age old problem with kit cars. My Caster
angle is as big as it will go and someone suggested that my wheel offset might be incorrect on the wheels I purchased (ET 21mm vs ET 35mm for Sierra
wheels). My original Sierra wheels have long been sold (doh!), so I have no way to check whether this is the problem - and none on ebay close enough
to me.
So, my question is does anyone have a spare set of sierra wheels they can sell me or even lend me for a weekend - for a small fee of course :-)
Anyone out there within 50 miles or so of Southampton that can help?
Thanks!
TimN
mikeb
| posted on 23/3/15 at 02:34 PM |
I've got a set of sierra build wheels, they are steels but might do the job.
Free to collect if you fancy a trip up to Northampton (nearer Wellingborough).
Mike
theduck
| posted on 23/3/15 at 04:01 PM |
I dont think increasing the track, which is effectively what you have done, would have any effect on self centering. Try pumping the tyres up?
JAG
| posted on 23/3/15 at 04:11 PM |
Increasing or decreasing the offset will have a marked effect on self-centring.
What you are doing is increasing the distance between the tyre centre-of-contact-patch and the steering centre (the point at which a line drawn
between upper and lower ball-joint intersects the road surface).
The drag force (created by the movement of the tyre over the road surface) acting at the tyre centre-of-contact-patch will operate at a greater off
set from the steering centre and will therefore create a bigger self-centring torque (force x distance = torque).
Good luck finding some wheels
Justin
theduck
| posted on 23/3/15 at 04:47 PM |
I even googled to make sure I wasn't missing something before posting that!
timnuttuk
| posted on 23/3/15 at 05:56 PM |
Thanks Justin!
duck, if it's any consolation, I also googled it, but after hearing first hand that someone on the cobra forum had the same problem I started to
investigate it. After increasing my caster angle, pumping the tyres, setting the camber and toe in, I was getting desperate.
Mike. Thanks I may take you up on that unless I can find something a little closer :-)
TimN
mikeb
| posted on 23/3/15 at 06:54 PM |
No problem, they are not going anywhere
serieslandy
| posted on 24/3/15 at 08:11 AM |
I've got a set of sierra steels, I don't know if the tires are any good. They are in rowlands castle (other side of portsmouth).
You can have them if you can't find anything else.
timnuttuk
| posted on 23/4/15 at 01:55 PM |
Thanks for all the offers. I found a set on ebay! After much measuring and testing I found that it wasn't the wheel offset that was causing the
problem, but the Toe-in. It wasn't out my much, but enough to stop self centring. Anyway, all fixed and IVA passed. Now while I wait for Mr.
DVLA to process my docs and send me my v5, I'm selling off all the old stuff I no longer need - including the wheel (with good tyres I have to
say!) - All listed in the For sales section and on ebay.
Thanks again guys!
TimN
avagolen
| posted on 23/4/15 at 05:56 PM |
Congrats on the IVA.
Holding my breath for registration from Swansea myself.
Yesterdays phone call was answered with :- we are just processing forms received on the 9th April..
The Answer for everything, but never the last word....
timnuttuk
| posted on 23/4/15 at 08:21 PM |
Thanks!
I passed on the 9th April (and had my application in the post on the 10th), so maybe they are processing mine next :-) From what others have said 3-4
weeks is normal. When did you make your application?
TimN
avagolen
| posted on 24/4/15 at 06:32 AM |
Hi Tim,
My application was signed for on the 16th April.
Is the 4 weeks total time or from when they start to process it?
She said Easter and sickness was the present cause of delay.
timnuttuk
| posted on 24/4/15 at 07:41 AM |
Sounds like yours is just a few days behind mine. From what other have said (and I believe it does vary), it is 3-4 weeks from when they first receive
it. So I'm hoping for early May. I'll let you know when it arrives. Hope my new steering wheel arrives first - I really don't want
to be out in a Cobra with a Sierra steering wheel :-(
Roll on the summer :-) !!
avagolen
| posted on 24/4/15 at 08:20 AM |
That's encouraging - sort of....
It will be great if you let me know, it may help my
frustration... this has been the only time in the
build that I am getting proper impatient.
serieslandy
| posted on 24/4/15 at 09:02 AM |
Well done on the pass, I know exactly what you mean with being impatient. I was with my application last year. It took about 3 weeks but IMO was
3weeks too long. It's so frustrating after all the effort to get the car road worthy and it passing for it to just sit there while someone is
paper pushing, really slowly.
