andrews_45
| posted on 22/8/05 at 12:01 AM |
Final leg of stripping the donor tomorrow me thinks
Right then,
I am booked off work tomorrow (hence why I am still up geeking at one in the morning) and plan to finally get the front hubs off. Both of the bolts
had well and truly siezed and sheared off when I turned them.
So, I plan to use spring clamps to retain the springs, then drill a small hole in the suspension dampers to drain off any fluid.
Once that is done I can chop the damper in half using an angle grinder and take the hub into work and use a pillar drill, do make a decent job of
drilling out the 'sheared off bolt'. - Unless that is... that someone else knows a better way...
violentblue
| posted on 22/8/05 at 03:19 AM |
sheared off bolts? drill it and use an "easy out" if its really stubborn, heat it up then douce with water it should pop free easily at
that point.
a few pics of my other projects
andrews_45
| posted on 22/8/05 at 01:10 PM |
awsome!, done it but of brute force and both suspesion units come out. now i'll take em to work and get the hubs off
