zxrlocost
| posted on 7/10/05 at 10:44 AM |
front brakes off my 4x4
quick one can I use the front brakes off my xr4x4 or is the soemthign different about them aswell as the car being 4x4 etc
jestre
| posted on 7/10/05 at 11:05 AM |
caliper brakes are caliper brakes. as long as you can mount them, use em.
(assuming they are strong enough for the application)
[Edited on 7/10/05 by jestre]
zxrlocost
| posted on 7/10/05 at 11:10 AM |
thats what i mean so they all fit any sierra front hubs
ReMan
| posted on 7/10/05 at 11:15 AM |
Should do, you just need to make sure and get the discs with the right offset.
www.plusnine.co.uk
desyboy
| posted on 7/10/05 at 07:52 PM |
xr4x4 calipers, caliper carriers and discs fit straight on to standard sierra uprights no problems.
hector
| posted on 7/10/05 at 08:24 PM |
just a note, i have put 4x4 callipers on mine build, I junked the original 4x4 hub carriers cos they had abs, got some standard sierra ones and there
is a slight offset between the caliper mount and brake disc, so i had to turn down 4 spacers- 5mm thick to bring the caliper back to the center of
disc.
