mcg
| posted on 19/10/09 at 06:37 PM |
Cortina Hubs Stub Axel Bolt
Hi, following responses from my previous thread
http://www.locostbuilders.co.uk/viewthread.php?tid=123306
I am good to buy these set of cortina hubs that I have found on line - only issue is, that the chap does not have the bolt that holds the hubs onto
the stub axel. Does anyone know where I can get two of these? Can quickly get into a false economy with this...Rally Design Alloy Hubs may be calling!
Although, thinking about it, will they include the bolt for the stub axel?
Many thanks
Matt
phil m
| posted on 19/10/09 at 07:49 PM |
should come with a set of bearings (cheap enough)
mcg
| posted on 28/10/09 at 01:27 PM |
Thanks for the info. I just spoke to Rally Design, and the bearing kit does not have any nuts (so to speak) with it, although it does have a split
pin. It sounds like all I need is the nut, retained by the split pin to keep it on. I get the impression from the chap I spoke to that its a standard
nut. Am I getting the wrong end of the stick here?
Has anyone got any pictures of there upright and hub components to help me get my simple brain around this very simple issue?!
Matt
