RickRick
| posted on 15/8/13 at 09:48 AM |
Sierra rear hub studs
Does anyone know if the wheel studs can be removed from the hub on a 4 stud sierrra rear? and how?
| posted on 15/8/13 at 09:59 AM |
Ideally a press, or push them out in a vice with a socket behind.
If your putting new ones make sure they are pushed right in against the hub face.
fazerruss
| posted on 15/8/13 at 10:12 AM |
Screw on the nut, hit with hammer. When pressing in new ones make sure you line up the splines or you may enlarge the holes in the hub.
"if assholes could fly this place would be an airport"
iank
| posted on 15/8/13 at 10:29 AM |
Caution needed if using a vice - see picture here http://www.locostbuilders.co.uk/viewthread.php?tid=180812
Anonymous
mcerd1
| posted on 15/8/13 at 10:31 AM |
+1 pressing them
not too difficult once you've removed the flange from the hub - just remember a get a new hub nut before you take them apart
(if you're changing the bearings and seals anyway they come with new nuts)
[Edited on 15/8/2013 by mcerd1]
