Russ-Turner
| posted on 1/3/07 at 03:45 PM |
Sierra master cyl pipe work.
Skodaman can't log in so I'm asking this on his behalf.
Can someone please explain what pipework attaches to what on the Sierra master cyl as there are three possible outlets, it's a three way split.
He's using Cortina brakes and an English Axle combo.
Cheers.
chrisg
| posted on 1/3/07 at 03:47 PM |
It's usually one to each front brake (The front two) and one to the rear.
But I expect an expert will be along shortly
Chris
cryoman1965
| posted on 1/3/07 at 03:54 PM |
Chris
Seems the expert has already posted
Nige
mike smith1
| posted on 1/3/07 at 04:11 PM |
No expert but picture may help, obviously side outlet to rear but wasn't connected at time of pic.
Top hole to Passenger side
Bottom hole to Drivers side
IIRC they need to be set like this as there is a slight bias to the drivers side.
[Edited on 1/3/07 by mike smith1]
| posted on 1/3/07 at 04:19 PM |
there is more than one sierra master cyl design.
belwo is antoher.
the two outlets on the front (side and bottom) go to front pipes.
rear side outlet goes to rear; pipe goes into 1 brake cylinder then across the axcel (there are clips to hold it) ot the other cylinder.
  master side view
Russ-Turner
| posted on 1/3/07 at 05:03 PM |
That's great, thanks for your help.
