Staple balls
| posted on 12/10/03 at 02:12 PM |
Removing wheels
for a 1.6 E reg seirra lx.
got to a point where i need the wheels off. and they won't move. at all.
any ideas? i've stood on the wrench thingy and jumped up and down to no result.
thanks
alex
rell
| posted on 12/10/03 at 02:18 PM |
put a pipe on the end of the wrench (steem pipe or thick walled pipe)
rell
| posted on 12/10/03 at 02:21 PM |
you could allso put some wd40 on it and leave it to soke.
Staple balls
| posted on 12/10/03 at 02:24 PM |
tried both of those, and i'm 18 stone, so if it's not moving with my weight on it, i have no idea if they'll move at all
rell
| posted on 12/10/03 at 03:06 PM |
are you turning them the right way? lol
if you turning the right way try hiting the studs with a bar and a lump hammer some times works if not get a biger bar or get you and a friend to jump
on the bar.
if all else fails drill the studs out
Ben_Copeland
| posted on 12/10/03 at 03:35 PM |
Heat them.... and definately make sure you are trying to undo them....
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
| posted on 12/10/03 at 04:32 PM |
yeap, id heat them, and also whack the wheel for good measure. and obviously make sure its anti clockwise!
easy way to heat fast is to weld something small on the end, probably more effective then a blow torch. make sire you dont obscure the nut.
Ben_Copeland
| posted on 12/10/03 at 04:35 PM |
and dont weld the nut to the stud
Ben
Roadster
Staple balls
posted on 12/10/03 at 05:39 PM |
yay
job done, thanks all, i eventually ended up getting my family to sit on the car, to stop the wheels turning on the ground and jumping on the wrench
lots
