The emotions went from ultimate high yesterday to very low tonight.
Yesterday I found out that my car doesn't need a windshield to be street legal in Arizona and I can get my license plate and tags as soon as I
want. I also found out that rather that trailering to the inspection station they will give me a 3 day plate to use to drive the car there. Then I
found out that they will not give the car a level 3 inpsection which I believe is similar to your SVA (well not quite so draconian) but instead are
going to give it a level 1 inspection which is just a numbers check on the engine to make sure it's not stolen...
Tonight I decided to take the car for a blast around the block. Got her up to some serious speed ---- and I neglected to latch the rear cover ---- so
off it flew, still attached by the hinge and so dragged behind the car for as long as it took me to lock up the brakes and get off the road.... Ohhhh
FUuuuuuuu-dge. The rear edge of the decklid is worn down at a nice 45 degree angle, there are some fractures and the paint is hosed. How's them
apples?
The good news is that the hinge held, the decklid closed back into position and I was able to drive home. Albeit at a lot slower pace. Probably a
couple hundred dollars in damage and I'll be able to rebuild that back edge, cut out the fractured area and rebuild it. That's the nice
thing about fiberglass, it's easy to work on.
What a shame...
Just goes to prove that we always get put back in our place whenever we feel like we have the world in our grasp... In this case it was me neglecting
a detail.
Very sad ... your car has turned out to be very special. I know you'll fix it and it'll be just as beautiful.
-Steve
Steve,
I've done it. You've done it. We've all done it.
Knowing this doesn't stop you feeling like a proper numpty but hey - a.) It could have been far (far) worse and b.) you could be having to do the
repairs and going through a level 3 test and getting it trailered...
Hang on a minute - You live in Arizona with hundreds of miles of fantastic roads at your disposal - Changed my mind - Don't have any sympathy
whatsoever
p.s. Your car is a work of art...
At least it was behind you and didn't whack you on the head
I wonder if some sort of bonnet open light might be a good idea. I notice a number of people have damaged body parts when things have come adrift.
Sorry to hear about the damage.
I've done it mate, and it DID whack me in the head (luckily I was wearing my helmet!
Mind you I do have a gorgeous carbon bonnet now by Carbon Mods!
Originally posted by Peteff
At least it was behind you and didn't whack you on the head![]()
Thank you for the words of encouragement gentlemen. I know I can always count on feeling better whenever I get on this site. #1 because everyone seems
to end up with problems of some sort and then resolve them and #2 everyone is pretty damn supportive.
Come to think of it, you could almost make a TV series out of this site, except for the fact that theres not enough back-stabbing going on! LOL
The idea of the light is awesome and I already have a door switch and a little blue light that would be very simple to wire up for that very
purpose.
I am going to swap out to some external latches so that I can visually see that they are not latched, rather than the hidden ones I have now.
It would be most helpful if you could you please post up photos of nice external latches and where you bought them?
I think the rubber, t-handled type would be ideal...
You say you want external catches now so you can see them,, wasn't that the idea in the first place, so you can't see them and they
don't spoil the stunning lines of the car, be honest do you really think you won't check the rear cover each time you get into the car in
future ??
Think of it as a lesson in life to teach you to check each time in future !!
In my opinion, external catches would marr it's stunning looks
Jason
Originally posted by Deckman001
You say you want external catches now so you can see them,, wasn't that the idea in the first place, so you can't see them and they don't spoil the stunning lines of the car, be honest do you really think you won't check the rear cover each time you get into the car in future ??![]()
In my opinion, external catches would marr it's stunning looks![]()
Jason
Oh man Steve, I can just imagine how you would feel
But don't worry, if you can make it you can fix it.
Re new catches, don't be tempted to fit spring loaded slam shut ones, as you then have to operate both catches at the same time to open, making
it a two man job if they are on opposite sides of the car
I also hope to fit some hidden spring loaded devices to pull my rear clip shut, possibly in the door jam, and then have some discreet "rally
pins" through the top surface of the rear deck as a second visual safety device.
Fred W B
The handles behind the seats sounds a great idea as you say , they wouldn't hurt the exterior lines, have you thought about some stays attatched
to the rear lid so when opened it couldn't fall back and touch the floor ?? All though I guess this attatchment would have probably snapped under
the extra loading of the speed factor
Jason
Another catch option.
http://www.aerocatch.com/
Sorry to hear about the damage, sure it will be back to its full glory soon.
[Edited on 16/9/07 by iank]
been there done that. mechanic at the garage forgot to put the hinges back on the hood after the anual APK (dutch) inspection, Mischa drove of and at
50km whoosh, bey bey hood!
just a shame it happens, good luck rebuilding!
grtz Thomas
I was also thinking along the lines of safety check straps to restrict how much the panel can open.
I have seen old inertia seat belts used for this. When opened slowly it offers no resistance, but tug on it and it locks up.
As a 2nd safety device I could add a center located block and tackle (on the inside face of the gt humps) that you wrap a small rope around. Just like a rope on a boat.
The t-handle rubber latches. Qty 2. Cost $7 each.
Steve, the Aerocatch was my choice. It has a built in tell tale - the handle sticks out unless locked shut. It can also be mounted completely flush
and without visible fasteners (bonded from the inside)
[Edited on 23-9-07 by RazMan]
Yes I have seen those and they are LOVELY. Very light, strong, nicely engineered. But at $85 each, just a bit ridiculous pricewise. I could see them
at 1/2 that price, but 85 clams!? get real.
$85 for a pair would be about what there are here in the UK I think. I am very happy with mine.
Some friends here in NZ have Sakers http://www.saker.co.nz/ and they have large crude latches for the rear cover that are located in the door jamb.
You can't get the door closed unless the rear lid is closed and the latches locked. The latch mechanism juts out and stops the door being closed.
Simple and effective. In a recent Targa here the rear cover of an Ultima opened up at speed and made the national TV news.
[Edited on 28/9/07 by Ratman]
