Best place for ABS/Plastic sheet?
cjwood23 - 9/1/14 at 02:25 PM
Guys,
Thought I'd be better off posting this in bodywork section.
I need some flat ABS (or similar) sheets approx 450 x 450 x 6mm as I want to make some slightly larger side protectors for the wifes wheel chair and I'm not paying north of £150 for them off the manufacturer!
So where's the best (most cost effective!) place to get black (or carbon effect....) sheets from?
Thanks!
Myke 2463 - 9/1/14 at 03:09 PM
Try,
Just Plastics UK Ltd
Market Street, Rugeley, Staffordshire, WS15 2JJ
Tel: 01889 223167
dinosaurjuice - 9/1/14 at 03:49 PM
would a aluminium-plastic-aluminium laminate be better?
theres loads of sheet sizes on eBay listed under 'dibond'. or a local signmaker may give you an offcut for a few quid.
I used it for loads of panels on Kit, its really easy to work with. lots stiffer than acrylic etc.
samjc - 9/1/14 at 04:06 PM
Can get 8x4 sheet of pvc whiteboard style sheet via ebay for under £40
rdodger - 9/1/14 at 04:51 PM
http://www.plasticstockist.com/ABS-Sheet.aspx?Page=1
cjwood23 - 10/1/14 at 12:35 PM
Thanks guys.
Will look at the links.
The ali-sandwich panel sounds good!
