Author: Subject: Help needed 1.7 puma (Sigma) fit in Sylva J15
theprisioner
posted on 30/3/12 at 09:30 AM Reply With Quote
I am trying to fit a 1997 Puma 1.7 (Sigma) engine in my Sylva J15 chassis. I came across this bit preventing the insetion into the chassis at the near side bottom rail (the bit with the joggle downward).
I have looked up the Ford TIS manual but cannot find this part referenced, I am sure it is there just a bit of a needle in a haystack at the moment.
Questions:
1) What is it for?
2) Any consequences in removing it temporily?
3) Anyone else found this problem?
melly-g
posted on 30/3/12 at 09:52 AM Reply With Quote
Camchain tensioner?
Norfolkluegojnr
posted on 30/3/12 at 10:48 AM Reply With Quote
A pic of where it was on the engine may help
Looks like some for of sensor to me. Is there any electrical plug on the end?
theprisioner
posted on 30/3/12 at 11:14 AM Reply With Quote
Gearbox thinggy
Sorry, your right no context!
adithorp
posted on 30/3/12 at 11:21 AM Reply With Quote
(I think) it's a detent spring/plunger on a selector shaft (5th gear?). No problem removing it to fit the box as long as you remember to put it back.
http://jpsc.org.uk/forum/
melly-g
posted on 30/3/12 at 12:10 PM Reply With Quote
oop's I didn't realise it was on the gearbox! I feel a bit stupid now for saying camchain tensioner.
Madinventions
posted on 30/3/12 at 01:08 PM Reply With Quote
Agree with above, it's a detent plunger. Put it back in once the engine is fitted and you should be ok.
Ed.
View my band website:
http://www.shadowlight.org.uk
Norfolkluegojnr
posted on 30/3/12 at 01:24 PM Reply With Quote
thread hijack - whats a detent plunger? new one to me!
adithorp
posted on 30/3/12 at 03:44 PM Reply With Quote
In this case...
The selector shafts have a grove in them, that when moved to select a gear, the spring loaded detent drops into and retains the shaft in that position. Just strong enough to retain the shaft in position but weak enough to be overcome when changing gear. It's what gives the gearchange it's nice, positive feel.
Detents (of different designs) are also be used to prevent 2 gears being selected at once and on gear lever assemblies to prevent accidental reverse selection.
Norfolkluegojnr
posted on 30/3/12 at 04:04 PM Reply With Quote
Originally posted by adithorp
In this case...
Every day is a school day.
Thanks!
theprisioner
posted on 30/3/12 at 04:38 PM Reply With Quote
Thanks for all your help chaps, it is a case of added confidence to move on.
theprisioner
posted on 1/4/12 at 09:44 AM Reply With Quote
More diagrams
For those still curious and to complete the thread:
Item 6 is I guess what we are discussing!
