I have sierra xr4x4 rear hubs,driveshafts,discs and calipers.
on the website it says i need a bracket to fit the calipers. but the mount is on the actual hub (does that make sence)
so do i need the brackets or not. im confused lol
which type of rear uprights do you have - ones for drums or ones for discs.
I think ( not sure ) that if you have the correct uprights then no extra brackets are required - but some one with a velocity will confirm this for
you.
Paul
I have disc rear uprights so i hope i don't need an adaptor. just thought i'd check. don't wanna scratch the new paint
if you have the disc rear uprights you dont need any extra brackets
no you don't need it watch this!
http://www.locostbuilders.co.uk/upload/03122004%20004.jpg
i have them facing the wrong side..
Tks
Thanks for that. i thought they were ment to go on the front
have you got the hubs on the wrong sides then.
also which side has the left hand thread! :S
The hub nuts tighten in the direction the wheel turns when driving forwards so when you are sitting in the drivers seat it will be the wheel on your left hand side.
