Just looking around for some alloys for my Velocity and was wondering on what size / wheel / tyre combination works best?
I've got the Sierra Front Vented Discs and Sierra 9" rear drums and the kit has the standard width wings front (180mm id) and rear (215mm
id).
I think the Sierra wheels are 4x108 PCD, with an offset between 35..38 and Centre Bore of 63.3....... HELP?
I was thinking on fitting 195/55/15 all round but don't think these will fit under the front wings and they may look a bit pants as they are
quite a large wheel.
Does a 185/60/13 look ok stuffed under the standard width rear wings (not too skinny??) or perhaps 185/60/13 on the front with 205/60/13 on the
rear?
I don't really want to go for the wider wings are I'm restricted on space for moving the car in and out of the garage!!!
check with luego for the width of their wings, but standard sierra wheels are 4x 108pcd, et38mm. I have seen 13-16" rims on various locosts and
upto 7" wide, have heard people using 205+ tyres, but again if width is a problem, check with luego first on measurements...
Ned.
Hi Gazza, if you have the standard front and rear arches the 185 tyres will fill the arches ok. The fitting are a standard Sierra fitment and off
set.
Regards The Luego Team.
