Just curious about how much other Vientos weigh.
The Luego web site says build weight from 600 -700Kg
Mine was 750kg with full tank at Sva,
Does mine need to go on a diet ( just like me! )
What did other Viento weigh in at?
Paul
bear in mind you do have a v8 on it....
some BECs weigh in at 600kg...
746kg wet weight...
760 Kg at SVA
Could loose another 30 kg If I could be bothered.
Built for comfort!!!!
Mine is a bit of a bloater then @ 800kg, must be due to me v heavy cast iron v6 ford boat anchor!!
I also have a 12 gallon tank aswell so there some extra weight there.
Must get me ass in gear and get the turbo kit on that will improve power/weight a fair bit.
think mine weighed in at 758kg, which I though was kind of heavy but it seem pretty average. I think Luego's 600 might be a teeny wheeny bit
enthusiastic.
Mine weighs in at 800kgs ,a bit of a bloater,but I put that down to the stainless steel panels.
Do any of you guys have the stainless panels? I'm wondering how much extra weight these add??
Dave
Had a good look over mine today to see if Icould loose some weight in the future..
Car seats - from MX5 - could save 10+ Kg with fiberglass seats
Rear parcell shelf - remake -could save 5Kg
The car was 748 kg at sva so with a lot of effoert could get it down to 730Kg at best
The biggest saving so far is alli pannels not stainless and carb inlet which is a lot lighter than the injection system and manifold.
Paul
[Edited on 24/2/08 by Paul (Notts)]
Dave J,
Mine is fitted with the stainless panels aswell.
These cars are v heavy anyway, i remember it took two people to lift chassis but they are very strong chassis thou. My aim is to get the power/weight
up so it performs better by turboing!!
cheers Colin
ali panels here.
I'm stainless panels and I'm the same weight as the ali boys - I wonder if I missed an important bit out!?!
just a thought, who has the windscreen fitted here, I do and it ain't exactly light.
I also have the granada diff, not sierra one.
No windscreen!!! Ha!!
Dont know my weight... or the Cars
But the car has to be 750-800Kgs.
Stainless panels all round, even the Battery shelf, and the bulkhead is lined with polished stainless. Bling bling bling
They are not leightweight cars. They are build for cruising and comfort. Just like me... I'm no sprinter. However the Viento is quicker off the
mark than I am
No screen here either, I guess mine is more of a bloater than I thought
Dave
Neil
just worked out what you left out during your build
an extra two cylinders
Paul
I wondered what that box of bits I'd mysteriously saved was
Never mind, seems to work OK without 'em
Originally posted by Paul (Notts)
Neil
an extra two cylinders![]()
Paul
