pathfinder
| posted on 1/1/06 at 10:40 PM |
Velocity front suspension/steering parts list!!
I’m going to the local motor factors (C.A.S.) on Tuesday and need to write my shopping list! Can anyone give me part numbers or vehicle model/year for
all the bits I should be ordering!
Steering rack clamps
Top camber adjuster thing
Bottom ball joints
Steering rack rod ends
Steering column rubber grommet and push in the plastic liner thing
This is for a sierra upright setup with an escort rack.
Have I missed anything off the list?
Is it best to get the ford bits from ford or are they the same quality/cost wherever I get them?
Cheers chaps
darrens
| posted on 2/1/06 at 11:40 AM |
I'm building a viento but they are the same
Bottom ball joints - Ford Transit - TC32
Top Ball Joints - Austin Maxi - QDL1117RHT (you refer to as top camber adjuster)
Track Rod ends - Sierra (all the same)
Steering column ruber bush - Sierra (I also require this)
Escort MkII rack
Steering rack clamps I managed to salvage from an old rack, local factor couldn't get them.
The part No.s for the ball joints I have written down on a scrap peice of paper so they might not be right, but they're definitely Maxi and
Transit
Darren
darrens
| posted on 2/1/06 at 11:45 AM |
balls
sorry not sure on the track rod ends for the velocity as you don't need the exstentions, anyone know if they're still sierra or escort
Darren
britishtrident
| posted on 2/1/06 at 03:16 PM |
QLD117RH is a Transit drag link
QSJ602s is a Maxi ball joint
QR1833 is a Sierra Track rod end rh
QR1834 is a Sierra track rod end lh
QR1384s is a Cortina/Escort metric track rod end
piddy
| posted on 2/1/06 at 06:19 PM |
Hi.
Rack extensions are needed on the Velocity Xt
Not sure about the Velocity.
[Edited on 2/1/06 by piddy]
