Stewart Kimber
posted on 31/5/06 at 09:05 PM |
Velocity clutch cable
Silly question but can anyone advise on type of spring for clutch cable to pedal. Build manual just says 65mm spring. Presumably that is an expansion
spring.
wicket
| posted on 31/5/06 at 10:01 PM |
Its a compression spring
jcs
| posted on 8/6/06 at 09:59 PM |
If its any help I used a cut down throttle return spring from a sierra carb.
| posted on 14/6/06 at 12:06 PM |
Not Luego related but
I find some handy springs in old car seats when I go scrounging in the scrapyard. What spring you need depends which side of the pivot point you put
it.
