adz h
| posted on 30/1/05 at 02:37 PM |
zetec install
hi
anyone had problems with engine breathing on a zetec i have put a crankcase breather on but it spits oil out when the revs are hi. Do i need to put a
baffle in the cam cover? my oil pressure is a bit hi but i dont think thats the problem
anyone got any ideas?
thanks
dozracing
| posted on 30/1/05 at 03:08 PM |
You may find its something to do with the sump and oil pickup etc.
Many of the Zetec installations fail to correct the sump baffling for the longditudinal fitment of the engine relying on the transverse layouts
baffling etc..
Think about fitting Raceline sump and wingage tray system. Or perhaps your engine is tired and breathing hard, rings shot? Try a compression test.
adz h
| posted on 30/1/05 at 03:20 PM |
thanks
i have heared that people mod the sump and baffling. does anyone know how? got any pics?
i will try a compression test
thanks
dave69isit
posted on 30/1/05 at 05:28 PM |
sump
some peps have used 18 cvh sump
adz h
| posted on 3/2/05 at 05:37 PM |
carried out compression test looks ok. oil pressure over 90 psi!
anyone got any ideas.
wilkingj
| posted on 3/2/05 at 07:25 PM |
Pressure Release Valve not stuck is it...
Best Regards
Geoff
http://www.v8viento.co.uk
adz h
| posted on 6/2/05 at 11:28 AM |
I have spoken to people about pressure relief valve, does anyone know if it is easy to get to and how to release it?
thanks
APR
| posted on 20/2/05 at 09:50 PM |
high oil pressure
just started the engine and also have high oil pressure on idle 90psi and up to 115psi running is this normal for zetecs?????
