craig1410
posted on 18/1/04 at 06:49 PM |
Anyone got the dims of the Velocity nosecone?
I'm thinking of getting a velocity nosecone from Luego to fit my +4" wider Locost. As I am fitting a Rover V8 engine, the extra height
should be advantageous.
However, Luego can't supply me with any drawings (basic dims only required) so that I can check suitability before ordering. Is anyone in a
position to give me a sketch of the critical dimensions of the nosecone and the top rails where it meets them? Also, I need to know exactly how high
the nosecone is from the top chassis rails.
Obviously I don't want to spend £100 only to find that it's a nightmare to fit. By the way, I know that the nosecone will need to be
widened to suit my chassis but I want to check that this is all I need to do.
Craig.
JohnN
| posted on 18/1/04 at 08:14 PM |
Height above chassis rails approx. 9.25 inches, 235mm
Width at rear of nosecone 680mm
Width at front of LA & LB 565mm
Along top chassis rail, rear of nosecone 305mm from front (ie the separation of the two, above, width dimensions, measured along J1 or J2)
Fits McSorley 442 OK.
Any clarification or other dims, U2U me
John
[Edited on 18/1/04 by JohnN]
craig1410
| posted on 19/1/04 at 12:23 AM |
John,
Thanks for the reply.
I'll need to havea think about this and do some measurements on my chassis but I'll get back to you to confirm anything which I
don't understand.
Thanks again,
Craig.
