nemesis v12
| posted on 27/7/10 at 08:19 PM |
IVA FAILED NEED HELP PLEASE
GREETINGS CHAPS
my motor failed the IVA today nothing major just the odd pipe clip and edge to be covered here and there.
the main challenge is ive used laminated glass for the quarter lights and rear window that are not E marked does any body know were i can get soem
tranfers from to say the window are approved or similar fix for the IVA man to look at
pleae help as this is the only BIG CHALLENGE
on the list
thanks in advance
GAV.
to old to die young
nemesis v12
| posted on 27/7/10 at 08:21 PM |
HERE IS THE CAR
http://www.madabout-kitcars.com/311/4505/4505picgallery.htm
http://www.madabout-kitcars.com/311/4999/4999picgallery.htm
to old to die young
MakeEverything
| posted on 27/7/10 at 08:25 PM |
Take the rear quarter out and leave it out?
Kindest Regards,
Richard.
jase380
| posted on 27/7/10 at 08:30 PM |
Hi Gav
is there nobody locally that does glass etching ? would look more permanent than a sticker .!!
just need to find what you have to mark on the glass.
nemesis v12
| posted on 27/7/10 at 08:35 PM |
just looking through ebay may be able to buy ohp acetate and print on that then stick it in the window but dont think IVA maa will be happy
and taking windows out isnt really an option but thanks for the thought
to old to die young
jacko
| posted on 27/7/10 at 08:50 PM |
Try auto glass i work for a bus company and they use to etch windows for us
blakep82
| posted on 27/7/10 at 09:01 PM |
thought only the windscreen had to be marked?!
or is it that only the windcreen has to be made of glass?
could you make up some lexan windows for the test? (check IVA manual again, i think it might have changed since i last looked at windows
________________________
scudderfish
| posted on 27/7/10 at 09:03 PM |
Can you not just take the windows out?
nemesis v12
| posted on 27/7/10 at 09:04 PM |
all glass needs to be e marked as of not long ago ;-(
windscreen
side windows
back windows
everyything
POOOOOOOOHHHHHH
to old to die young
t.j.
| posted on 27/7/10 at 09:08 PM |
Is it allowed to replace it with plastic?
I personal would not like to have real glass behind my back unless it is safety glass.
blakep82
| posted on 27/7/10 at 09:39 PM |
always read the manual
3.
Windscreens must be “Safety Glazing” made from glass and display the relevant markings. (see note 2 and table 1)
4.
All other windows (including sunroofs and removable glass panels) and side-screens must be “Safety Glazing” (which may be made from glass, or from
plastic)
locobri
| posted on 27/7/10 at 09:41 PM |
I'm sure, if you can show documentation showing that the windows are laminated that counts as well!
eg. a reciept from the kit company.
Could be worth a phone call
[Edited on 27/7/10 by locobri]
minitici
| posted on 28/7/10 at 10:33 AM |
I think you are going to have a draughty car unitl after IVA.
I think the IVA guy will see through your cunning plan (no pun intended.....)
nemesis v12
| posted on 28/7/10 at 01:29 PM |
surly we cant present a car for IVA with 3 windows missing??? if it was a 7 or cobra type it wouldnt be a problem but this must be against the rules
as its a fuly enlcolsed cock pit ie with a roof.
to old to die young
interestedparty
| posted on 28/7/10 at 02:40 PM |
If its not fitted they cant test it, nothing in the manual about cars having to have windows
minitici
| posted on 28/7/10 at 06:13 PM |
I would whip out the windows and fit some edge trim round the openings.
However I have read, on other forums, that the IVA inspector may class a closed vehicle with window apertures as "an incomplete vehicle"
(if no glazing was fitted) and therefore will not test the car.
I hear that the exemption to use kite marked BS glass has been extended to April 2011.....
[Edited on 28/7/10 by minitici]
Further reading indicates that not fitting side and rear glass may be acceptable so long as the glass was not designed to be bonded in and be a
structural part of the shell.
So traditional rubber seal mounted glass may be OK to leave off.....
wilkingj
| posted on 30/7/10 at 08:35 AM |
Talk to your VOSA man and ask what they will and will not accept. Also read the IVA manual.
Best Regards
Geoff
http://www.v8viento.co.uk
40inches
| posted on 30/7/10 at 10:18 AM |
Blake is right, you will have to have the glazing marked It may be worth checking on http://www.gt40s.com/forum/ to see what they do.
  Safety Glass
[Edited on 30-7-10 by 40inches]
