lugo35
| posted on 6/10/04 at 07:58 AM |
viento rad
hi does anyone know what size rad will fit in viento. i am going to use v8. What donor do they come out of cheers andy
G3OFF
| posted on 6/10/04 at 03:47 PM |
hi,
not sure what donnor the rad came from but i purchased mine direct from luego.. its was for me v8
no such thing as to much power......
lugo35
| posted on 6/10/04 at 05:31 PM |
know luego got em but 190+ !!!!!! want to try n save the pennies
g3off could you measure your rad up would be very gratefull cheers andy
wilkingj
| posted on 8/10/04 at 07:15 PM |
Hi, I have the same problem.
I intend to check out my Local Serck / Marstons Radiator company, as they will make you what you want. This may be dearer than Luego!.
A V8 makes a lot of heat, and needs good cooling. I am interested in your replies etc.
I have also thought of a Land Rover 200Tdi Diesel Rad, as this is big capacity, and small size, as the intercooler takes up 1/4 of the front panel,
and can be removed. Its also got a built in Oil Cooler as well.
Geoffw
Best Regards
Geoff
http://www.v8viento.co.uk
ChrisW
| posted on 10/10/04 at 11:37 AM |
I've used a Polo rad but I had to make up some spacer brackets. I'm only using a 2.8 V6 tho which probably produces less heat.
Chris
My gaff my rules
Donners90
| posted on 10/10/04 at 03:52 PM |
Dimensions
Viento Rad
Overall size: W=580, H=395, D=95
Core size: W=57.5(ish), H=28.5, D=60(approx)
Bought the Luego Rad to be on the safe side with the V8. Auxiliary cooling by way of Metro fan!! See pic
HTH
James
lugo35
| posted on 10/10/04 at 06:23 PM |
thanks for that donners will have to have a look around . got pair of kenlowe's that took off rangerover for fans they both might fit
andy
