wicket
| posted on 4/3/05 at 06:45 PM |
Locost Castor Angle
I have been using the Velocity build manual as reference for a Locost build & set the spacer washers as suggested which gives 2-3 deg neg, I
measured mine and its about right.
Can anyone with a SVA'd Locost or Velocity and on the road OK that setting for the castor angle, does it self centre OK
Surrey Dave
| posted on 5/3/05 at 11:50 AM |
2-3 degrees of caster sounds a bit low i think the Locost design aims for 5 degrees , which still seems a bit low on mine ,could do with more self
centering .........
[Edited on 5/3/05 by Surrey Dave]
billy
| posted on 8/3/05 at 11:21 PM |
ive got loads on mine and it only just shows signs of self-centering, ive had to modify the bottom bones on mine to give me more. phew
luego-lo-cost finished,vauxhall 16v 2.0,twin 45s de-dion rear set up
ned
| posted on 9/3/05 at 11:02 AM |
i think the book chassis is supposed to have 5.5, but depends on wishone design as Billy says. Lower pressure in the tyres helps at SVA time as does a
bit of toe out..
Ned.
beware, I've got yellow skin
