Ferg
| posted on 10/4/05 at 07:34 AM |
Handbrake Cable Anchorage
Having got the cables for Tom's handbrake I discover that they have this bit on them......
..but the chassis already has some welded on brackets to take the cables.
Which is the better option? I don't really wnt to remove the brackets from the chassis as it'll disturb the powdercoat, however it looks
the better option from an engineering point of view.
[Edited on 10/4/05 by Ferg]
ned
| posted on 10/4/05 at 07:51 AM |
whats the chance of using a rivnut to attch the bracket on the cable and leave the existing chassis bracket alone?
beware, I've got yellow skin
Avoneer
| posted on 10/4/05 at 08:01 AM |
That would be awkward to spin round into a rivnut!
Cracking idea for those of us still plannning and building a chassis.
What's it from???
Pat...
Triton
| posted on 10/4/05 at 08:05 AM |
Austin "All aggro" Use two of 'em if Live axle.
With summat fabbed up then welded to axle
Mark
Ferg
| posted on 10/4/05 at 08:18 AM |
Yes, it is an Allegro cable which Luego have informed me is the required cable for the drum braked IRS Velocity and in the build manual it shows nuts
holding what appear to be these bits secured to the chassis, BUT our chassis, which was built after the instructions were printed, has some welded
brackets on it.....
MikeR
| posted on 10/4/05 at 10:18 AM |
how are you attaching the other end to the hand brake? i've got to make that bit next and i was expecting a much larger lump at the end of the
cable to pull on.
Marcus
| posted on 10/4/05 at 07:08 PM |
Maybe I'm missing something here, but if you mount that bit to the chassis, won't the handbrake come on when you go over a bump?
I had to weld a bracket to the axle to take these cables.
Marcus
Marcus
Because kits are for girls!!
Ian Pearson
| posted on 10/4/05 at 07:14 PM |
Ditto.
Ferg
| posted on 10/4/05 at 07:30 PM |
I suspect that the cable is fitted the other way 'round on the IRS Velocity. The end that this stop is on is at the lever end and the yoke on
the inner adjacent to it goes on a balance bar affair pulled by the lever.
The nipple on the other end goes into the swinging plate attached to the Sierra brake shoe.
Does that make sense??
pointy
| posted on 13/4/05 at 07:05 PM |
If I can add my bit
I too am confused, I have the same brake cables and found them impossible to fit.
I have since tried to fit mk2 escort cables but they are a bit short.
If someone has a rear drum luego please help.
Andy p (im not thick...honest)
