Avoneer
| posted on 21/5/05 at 02:19 PM |
Roll bar/cage requirements and chassis
I am currently nearing completion of my locoblade chassis (not ST one).
If I was to eventually race in one of the 750 classes, what requirements do I need for the roll bar/cage?
Does it have to be a full cage, or will two rear drop bars, a diagonal in the main hoop and a long diagonal from the front, top, middle of the main
hoop to the front outside corner of the passenegr footwell do?
All bars are 50mm x 2mm wall.
Is there anything else I will need to take into consideration with the chassis that is different from normal road going ones?
Pat...
GazzaP
| posted on 21/5/05 at 02:23 PM |
I bought my roll cage from brian mitcham who races in the locost championship if you do a search on here for him i'm sure his number will be on
it.
gary
www.gmpmotorsport.co.uk
Jon Ison
| posted on 21/5/05 at 02:57 PM |
If its for RGB you dont need the full monty cage, strange but true.
the main failing point on a lot of RGB cars has been roll bar height, without checking regs i think its 2" minimum above top of helmet, thats
the one too look out for.
[Edited on 21/5/05 by Jon Ison]
