right. in the early stages of my build still but trying to find out all the details so i know whats what when the time comes. 1st of all lights.
aslong at theyre e marked theyre ok yeah?? 2nd mirrors. i plan on using bike morrors with built in indicators. aslong as theyre not sticking out more
than the rear wheels im ok yeah?? and also do i need reflectors on the back along with lights/stop lights, indicators and a fog and a reverse lamp??
and whats the crack with a roll cage. im planning on putting the rollbar on the back like most do and want bars across the 'roof' and down
the sides of the screen. will this be ok as im guessing itll make it kinda tricky to get in and out?? ive seen cars like this before but was just
wondering. And can i use perspex for the screen or does it have to be glass??? and what type of switches do i need to use for all controls such as
hazards etc.?? ive got loads more questions but will save them for later. Anyone got a link to a full sva checklist so i can carry out my own sva
before i go?? like light min and max heights etc?? thanks.
[Edited on 3/12/08 by Z20let Corsa]
All yes
except for
Must be glass unless its very low and you can see over it, best to use savage switches, bike mirrors should be E-marked too. Mount them on the roll
bar front pillars
cool. like i say does anyone have a list of requirements for the test so i can go over everything?? i dont want to make stuff to find itll fail the test on it!!! Thanks.
Diagrams detailing light position requirements can be found on the westfield world site along with other useful sva data.
good luck.
good luck.
This thread has some info.
Westfield SVA info, including lighting stuff.
Mirrors should be OK subject to radius and size being OK.
Roll bar/cage should be OK
Reverse light not required
Best to avoid having any screen at all for SVA so you don't have hassle with sharp edges, etc.
Switches need to be radius-friendly except in an exempt area. There are requirements for what warning lights you need.
The SVA manual is quite a good source of reference info ;D, and you can get clarification and real-life experience from this site,
E markings on lights refer to their lighting properties only. A correctly E marked light can still be failed for poor positioning or sharp edges of
its housing.
SVA is the current guide only and will have been replaced by new IVA regulations by the time you get to the test and those regulations are yet to be
finalised despite being due to be implemented in april 09.
[Edited on 3/12/08 by Dusty]
IMHO, I would invest in the IVA guidelines.... I wish I had a copy when I was building the car, that way you can quickly flick through it and get THE OFFICIAL answer..... Plus if you take it to the test and show th tester that you built the car to the book, it may be harder for them to "find" things to fail it on... Just incase you get an analy retentative arsehole as a tester...
where would i source them then please?? thanks.
The best money I spent during my build was buying the SVA manual. Well that and an R1 engine! Order via VOSA web-site.
Yes, its expensive. Yes, you can find it on-line. I just find the hard copy easier to use (a lot of it needs reading several times to understand) and
it saves buying bits you can't use or wasting time on stuff that won't pass.
Lights don't have to be E-marked either, they just have to have similar characteristics to ones that are.
Fit a screen after test if possible.
No restriction on mirror protrution as far as I know.
adrian
[Edited on 3/12/08 by adithorp]
Getting a copy of the IVA manual (SVA if you're seriously quick builder) would be a v good idea....
E marks have to be the right one as well. The manual lists the marks for each lamp. So you might have E marked lamps (bike specific for example) but
still fail because they aren't bright enough.
adrian
Look on my website here:
http://gtslocost.locostsites.co.uk/downloads.htm
There is a copy of the draft sva manual there. It is draft, however there is enough info in there to get through the test and understand the
requirements.
Anything marked eSVA is irrelevant (most of the first chapters)
Yeah???
