will one of those simply red plastic cut off keys on the earth circuit be ok for the sva
I think you need to have at least 2 anti theft devices.
I have an immobiliser, ignition key and steering lock.
i'm planning one of those transponder jobbies too
thanks mark
i have the standard steering lock fitted so might be ok im also in bristol might see you at castle coombe this summer
thanks mark
Originally posted by M HIGGS
thanks mark
sva only requires a standard steering lock
Passed my test with the steering lock and key for ignition. Since then i have fitted and immobiliser due to having keyless start
and removable
steering wheel to be on the safe side
Adam
