hi folks, ime about 3/4 way through the build, ime aware iva is taking over sva, am i right in saying i should complete forms and take for sva, even for a fail? does this mean then that the car, will only ever be tested after that, with sva rules? (if you get my jist)
If you take the SVA test and fail
you have 6 months to get it passed.
HTH David
Just be careful, not sure if you took a car that obviously woulnd't pass, if they can refuse to test it, then think you'd have to re apply.
Yes, but the tester can refuse to test it if it isn't ready. Or I think, if you get so far through the test and the car breaks down and he
can't go on, it doesn't count as a fail (I think).
Mike
did i read about a kind chap does does all the paperwork for beer tokens?..running out of time fast...thanx for help
that will be paul jepson, martin at nottingham sva said if the car is obviously not finished it would be refused a test and you will have to book again and pay again
got to do lighting, front wings, rear wings, side panels, passenger seat, tunnel boxing in...what do ya recon?
