Hello All,
Ive been looking for a lo-cost inspired car for a while now that I can build from scratch but benefit from an established design.
Having stumbled one evening across Steve Grabers website (www.grabercars.com), ive been bitten by the “la bala” bug. The only issue is that no one
here in the UK has one and that I would have to import the body work…
Importing issues aside, what do you all think regarding getting one of these road legal in the UK ?. Can any of you with SVA/IVA experience see any
major issues to be aware of ?
There dosn't seam much talk of the La Bala here on this forum, has anyone else considered building one of these ?
Kind Regards,
Tris
[Edited on 8/5/09 by Tris]
[Edited on 9/5/09 by Tris]
Steves a member of this very forum.......
Thanks for the replies.
Yes, steve and i have been in comunication via email for a few weeks now. Top chap who always has made time to answer my questions
No kits have yet been exported.
Tris
Hi guys, just to fill you in on the particulars of the La Bala. I've had mine registered and licensed for street use in the USA for over 2 years
and have put over 23,000km on the odometer.
La Bala is intended to be a low-cost and dependable middy and as such uses Toyota components for all wheel hubs and brakes, steering rack and column,
shifter assy, radiator and various other misc parts throughout. The engine can be Toyota from the donor or almost any FWD driveline.
With respect to the Q plates (and I admit to knowing virtually nothing about this issue) - I am not sure that all of these donor components could be
replaced with new parts without significant cost or effort.
I've had some inquiries over the past year about exporting to the UK but no bites as of yet. I would love to have Tristan and others building La
Bala's in the UK and Europe. Let me know what I can do and I will help out any way that I can.
Just from looking at the pictures I can't see any reason it wouldn't pass IVA.
A slight concern over the outer edge of the air intake on the 'door'? maybe? that's about it.
Steve,
You've probably done this, but the IVA manual is free and downloadable. If you have the time it might be worth have a check through it on your
part so you could 'certify' you cars as being IVA passable. This would apply to both the UK and our European friends who are forced to IVA
and register their cars here and then register and import them into their own country.
It wouldn't have to have Q plates. It could be age-related if one was careful and selective with donor car choice.
If one was 'creative' with part selection and receipts, I can't see why it couldn't get a new plate!
James
Main 4 possible stumbling blocks I can see would be:
Potential radius issues - easily solved by checking IVA rules
Headlight height - again check IVA rules, if issue arises then there is the potential to raise ride height etc.
Windscreen wipers - can't see any evidence of these on your car, Steve
Seat Belt Mount Positioning
[Edited on 8/5/09 by stevebubs]
Speaking for someone on Steve's side of the Atlantic, who has mostly built a car very similar to an MK (chassis made in Canada), I can say that it is considerable expense shipping things like bodywork. If he can set up some sort of distributorship there you might make it remotely Low Cost, but until then, you are looking at decidedly High Cost. Just believe me!
Thanks for the replies. Currently reading in depth the IVA manual
(http://www.transportoffice.gov.uk/crt/repository/M1%20Inspection%20Manual%20May%2009.pdf) to see if anything applies.
Stevebubs - Am i right in thinking that i have to have windscreen wipers ?
Rk - Yes i know. If only it was still $2 to £1 !!...
If you have a windscreen then you need effective wipers, windscreen washers and demisters (hot air fed by heater, or electric). And, of course, the windscreen needs the appropriate markings
John
Addressing some of the issues directly related to passing the IVA:
Although there are no wipers or demister on my prototype (it's never rained while I have driven the car!) I do have a basic design in place for
installing them using a remote cable operated wiper system which many of you are familiar with. I'll be installing my set of wipers this year
before the monsoon season. The windshield glass comes from the 1996 Geo Metro (aka Suzuki Cultus). I don't know if that vehicle was made
available in the UK? In any case the demister vents from the original Geo Metro can be installed with little effort and the fan system is whatever
fits under the considerable open space under the dash. I did originally have an aeroscreen in place during my initial inspection and there were no
wipers required with aeroscreen which made it much simpler for me at that time.
Unrelated to the IVA issues - I have checked shipping rates Phoenix to London and the freight charge is around $1,300usd. The crate is another $300.
So that's your premium over the American version. FYI the freight charge Phoenix to New Hampshire (West Coast to East Coast USA) was $550.
Just another thought as the car is 'open top' then all the inside has to have the tedious 2.5mm radius, anything the inspector can get his
100mm balls near. Or does it have an optional roof & side windows?
Alan...
So, lets have a ballpark figure for the kit! I like it a lot and for once in my miserable life, I have the funds to buy whatever I choose (within
reason!). Can we also have a list of the donor parts needed.
We'll not include shipping for now as there are lots of companies who will hire out space in a container for not much money. Cheaper if Mr Graber
could fill a whole one!
I am sure I am treading on very thin ground here with this information. prices usd...
If you build from the plans (currently 150+ pages, metric/imperial double dimensioned, cost $99), purchase my bodywork $4900 (not including freight to
the UK), and then you purchase all the steel and source all of the donor components yourself locally following my parts, list the car should cost
between $13K and $15K to build. Depends on your choice of engine and your ability to shop frugally. FYI I sell a roller-minus engine for $25K. Engine
of choice is usually Toyota 4AGE 20v or GM EcotecSS if you want more power. I sourced a JDM 20v 4AGE for $1,200 with 5-speed and it included shifter
assy, wiring harness uncut, 1/2 shafts and uprights, full intake, ecu and fuel pump.
I don't have any sales volume in the UK at this time mind you, so it's a bit of a technicality to be mentioning the cost of things. All
prices are what my USA builders are experiencing.
Moderator, feel free to remove this post if it conveys too much information about sales.
Hello steve,
Quick question and picking up on something already said - do you think the shipping costs would be reduced per unit if 2 or 3 sets of bodywork / steel
sets were shipped over together ?
Not planning on buying a fleet of these btw, just interested to see if there's any potential cost savings to be made if interested people in the
UK club together.
Btw, this graph makes painful reading but it looks to be slowly climbing again
http://newsvote.bbc.co.uk/1/shared/fds/hi/business/market_data/currency/11/12/twelve_month.stm
Tris
[Edited on 11/5/09 by Tris]
Perhaps if there was enough interest Steve could have a european agent (someone who's already good with fibreglass), and send a set of moulds
over - make the panels here and take a licence fee per set made? Obviously this takes a lot of setting up/trust/quality control issues...
Regards
Hugh
Tris, one year ago could have been 2 for 1 exchange rate month! what a shame.
I am open to having a Euro Agent and have actually thought about it many times over the years. I am not certain that I have the resources to expand in
such a way this year yet. My current business model dictates slow growth because I do understand the risks involved in uncontrolled growth and lack of
capitalization. I have resisted investor funding up to this point and still want to develop my doors and 3-piece hard top design before broaching that
subject. So that I have a stronger negotiating position.
I would be amenable to sending a number of kits across the pond in a container but that may be jumping the gun too. I think there has to be one
dedicated and brave soul (such as Tris?) to take the initial plunge of building a UK/Euro La Bala from which the seeds of such a venture could grow.
This is of course just a speculative conversation at this point!
