I have to use quite a large battery, and there simply isn't going to be enough room under the bonnet. In my donor it was located under the back
seat, so the long battery cable is just about the perfect length to locate it in the boot of ly locost.
My main concern is having it so close to the battery, is it allowed? Do you have to completely separate them in different compartments?
Thanks,
Sam.
Mines in the passenger footwell and passed SVA no problem.
Is it being so close the petrol tank your concerned about?
minis were like that, and more recently my BMW is has the battery in the boot. it'll be fine
only real down side is the huge heavy cable run to the front which needs a heavy cable due to the voltage drop over that distance. Not really the best place for a battery if you can help it.
My MK's battery is in the boot:
Boot/Battery
Reasons:
I didn't like the idea of securing it on the scuttle,
There's enough weight up front already,
Benefit of the weight over the rear wheels
John.
BMW 3-series all have the battery in the boot - no worries there.
If I recall - "battery acid + petrol = FIRE" so might not be so great in a rear end accident where battery will be shattered and the tank
of a locost is vulnerable as well.
Don't forget in tintops etc the battery is separated from the tank by the floor of the boot etc.
I can't see it being a problem. Its not a problem on motorbikes, nor is it an issue on classic cars. Plus LOADS of people in the modding scene
move thier batteries to the boot space to tidy up the engine bay.
Incidently, lead acid isn't a source of ignition for petrol. I'd be more concerned with the poor contacts on the battery being a source of
ignition.
well, as lpong as its properly clamped down then its fine. acid + petrol won't cause a fire i don't think. petrol can only ignite from flame or spark, so as long as the battery won't touch the tank, it can't move and is clamped down right, and you've got the right covers on the terminals its fine
I think the only issue if I was a tester would be were the fuel tank vents.if it vented into the boot area I would have an issue,if the end of the
vent pipe was in clean air ( outside bodywork) no issue
tony
As opposed to venting under the bonnet?
I don't understand.
My fuel tanks not under the bonnet
I don't understand.
Ahh, I was confused I was, in my last post I asked if it was ok to build a box for the battery, as long as the battery box is vented.
Now I get it.
