had my retest today and got through on most of my fails from the last time - however there were two points that I failed on :
1. too much front bias on my brakes
2. emissions - despite taking the car to a rolling road session to get the powercommander mapping done the car failed big time with both CO and
hydrocarbons both being over 4
I asked the tester what sort of brake balance I should have but he couldnt tell me as the computer does all the data analysis. As I had the bar fully
biased to the front I will move it to the centre of the pedal and hope it does the job.
As for the emissions I dont know what I can do about them as I was relying on the RR to get them fixed
unlucky, shame about that. hope you can get emmsions sorted out, and the blance bar, does sound hard to get it right, i did not have one.
good luck
stuart
What brake setup have you got (M/C size, brake specs etc).
Can you take your PowerCommander with you - basically, you lean it out until it works. My tester gave me a good 30mins of tinkering on his machine at
my retest!
I had both of these items to sort on my car for the retest 2 weeks ago. You will get there....!
Did you tell the rolling road operator that you needed to have meet specific emissions requirements as he may well have set the car up to get the maximum power
Rolling road set up won't get emmisions right for the test. It needs setting specifically to the teat requirements.
"...both CO and hydrocarbons both being over 4 " is a bit vague. HC of 4ppm would be low/pass. CO of 4% high. We need more detail to be able
to advise really.
adrian
I should have added a few deatails about my spec
brakes - wilwood powerlites at the front with sierra calipers at the rear. The M/Cs are a .625 front and .750 rear
emissions - the RR operator knew it was for SVA. I am a complete numpty when it comes to powercommander so would not know where to start to tweak
things. Also the SVA regs seem very strict in Northern Ireland so dont know whether they would let me connect the laptop to the car during the test.
The tester did try his best to help me by using different machines but things were that bad my car broke both machines !!!
Go back to the Rolling road and Kick up a stink, If they were ment to set the car for SVA they failed , You have the proof.....
Marky, was it Jack F that set the car up for you? I got my car setup there too for the SVA, all be it I have carbs so it was a dynojet but I passed
emissions on my first test!
As for the brake bias I have my balance bar set slightly to the front and I just about passed! I would set it in the middle I reckon.
I have my retest down there on Monday, failed the first test on harness heights, the engine venting to air, the radius of 2 exhaust brackets, an edge
under the dash, and the radius of the bottom of the dash. Wasn't too bad thankfully and fingers crossed I'll pass the retest!
All the best getting sorted.
[Edited on 15/6/09 by PaulYDP]
Hi Paul - yeah it was jack that done the map - since then I have discovered that one of my TB sliders is sticking (see other thread on here) and this
may have affected the emissions test
There is a local garage with a brake testing machine so was planning on going there once I have a new bias bar in place - will try a middle placement
to see how it goes
sounds like you had a decent fail - good luck with the retest
You are voicing my fears ref the brake bias bar set up. You are doing the SVA - the requirement for locking the bias bar has changed with the
introduction of the IVA (as I'm sure you are aware) in that the bar has to be locknutted, the nut welded on, and the rest of the thread filled
with welding 'so as to make further adjustment impossible'. All very well, but what if I set my bias incorrectly - as you seem to have
done? - Failed test - then what - replace the pedal bush + bias bar etc after cutting the old one out - resetting it with new parts - then IVA
retest (@ £90 a throw!!!:mad
Sorry, but I am very worried about this and my test is months and months away!
Oh, and good luck with your retest!
[Edited on 12/6/09 by stevegough]
