windscreen supports. - Radius compliance
stevegough - 13/6/10 at 07:29 PM
Just assembling my windscreen - I have some S/Steel supports which are 2.5mm thick - does anyone know if they have to be radiused to 2.5mm or can they be merely 'blunted'?
See IVA manual, section 12 (interior fittings) - there is a reference in Annex 1 “Specified Zone Exempt Areas” to the windscreen side pillars - does that mean they are exempt?
Anybody had a fail for this?
austin man - 13/6/10 at 07:49 PM
fit after the IVA then the radius isn't a problem
speedyxjs - 13/6/10 at 08:08 PM
^^^What Austin man says. Thats what im doing
snapper - 14/6/10 at 05:50 AM
It is worth blunting or you can glue on some edge trim
stevegough - 14/6/10 at 08:20 AM
Thanks for the replys, but I am fairly committed to fitting the screen - Austin and Speedy - Built a heater, fitted washers, wipers are next - so - snappers idea looks good to me - found this on ebay - will it do the trick? note its width is 4.5mm - will it be 'round' enough?
Trim link
Cheers!
