well it failed, was up at 5 and got the car off the trailer an ready for 830 would reccomend usin notts as they were really helpful
it failed on
the seats were mounted too high from the floor, been paralysed and in a wheelchair it is hard work gettin in and out of the car so havin the seat
about 3 inches from the floor makes it lot easier for me, it failed because the base of the seat and the measurement to the seat belt mount was too
close by 5cm, lucky my dad has an mk and we will be usin them
mk stamped me a a vin on a piece of metal and i welded it on, they say that there is a spacin to big between the numbers so needs redoin.
the front lights on the mk which i got from them he said they were too low they need lots of washer or a spacer to lift them up. the lense has to be
over the front arch in height
need some mesh between the nose cone and the side panel as his little tool went in the gap.
The rear tub on the mk the bottom line on the fibreglass back panel is not radius so he suggested stickin on some rear arch rubber.
The front arch rubber needs stickin on with glue,
The key switch needs fubber stickin on it yes the key switch as its in the centre console.
passsed the noise test emssions brakes lights so dont think its too bad. speedo was spot on aswell
booked it in for next tuesday so got few bits to do
Thats a good fail, nice one.
Thats about as good a fail as you can get, deffo pass next time then.
Nice work...
Rich
Thats a very good fail indeed!
most of the fail points werent really your fault either cant believe they require the bottom edge of the rear tub to be covered ott!
also..
Dont really understand the mesh between the nosecone and sidepanel can you elaborate?
That's a really good fail mate. If you need a hand with owt this weekend just give me a shout but sounds like you'll have it done piece of
cake!
They liked your clocks then
if your registered disabled and say the seat is a disabled adaptation then they cant fail it as far as i am aware.
i have an indy r so the front nose cone and side panel have a different gap i think.
when i have done it will post a pic so you can see but where the a arms go the side panel only comes so far down then there is a slight gap then the
nose cone.
the clock were fine no issues, to fill your all in i had gsxr 1000 clock that needed radius, i melted some thin plastic in the oven pushed it on the
clocks whilst it was red hot and all floppy it hardened in 10 secs and was moulded round the clocks bit of sealant all the way round jobs a good
one,
i had no had controls on it and it only has a auto clutch and button for the gears and they would prob only do the drivers but they said that it was
for if you crashed it would crush your spine, dont want to do that again !!!!
i think i might put a list of things that peolpe on here things i have picked upand help from mk have helped to get it through to help others for
example the sticker needed on the brake master cylinder show what fluid to use also for the vin plate you can use a sticker and dont have to stamp it
on
[Edited on 21/6/10 by raptor700]
You can have a sticker for the VIN plate!!
yeah my bmw has a sticker that why he said it my sticker is in the door , so yeah you can have it!!!!
Good result! - because the end is in sight.......
........ (especially as the examiner was putting his little tool about!!!)
Well done, that raptor!
What was wrong with the vin spacing? I've got a plate welded on too but also have a sticker with the vin on.
im expecting my IVA date this week so if i got a fail like that i will a happy bunny...be even better if it passes;o)
Isnt the space within the front wheels on open wheeled cars is exempt as of the latest version of the manual?
what edge was it on the rear?
as far as i'm aware adaptation for disabled access should exempth that part of the test. to fail it on that should put them contravention of the DDA?
nemesis v12 you will be ok its not how high the seat is its where the seat belt mounts are you are quite high on an indy they go back down the rear of
the seat about 4 inches.
basically with the spacin there was a slight space to pu another number in bit piccy but that how it is.
this is the pic of the bottom of the back panel that needs a raduis on it
[Edited on 22/6/10 by raptor700]
pic of rear tub has to be radiused[img]http://locostbuilders.co.uk/upload/a1167853-phpt8BiHYAM[1].jpg[/img]
this is the space that needs meshing
also a quick pic of the car[img]http://locostbuilders.co.uk/upload/a1167860-phpv4gc3pAM[1].jpg[/img]
the part that needs remeshing[img]http://locostbuilders.co.uk/upload/a1167861-phpzHI8GdAM[1].jpg[/img]
MK do that differntly now, the panel goes all the way to the nose with holes cut out for the wishbones.
my kit is about 18 months old so like ya say they have changed stuff
