hi all
does it matter that the height of my chassis at the rear is 1.5 " higher than the front. The back measures 6 " and the front 4.5".
This is with no fuel or any body sat in it. The bottom wish bones are parallel with the gound as is the stearing rack.
No problem at all. Mine's the same at standstill.
cheers for that pete
+ you will generate a tad of down force for free at the rear, trust me, you need grip at the rear.
Yep, plus with fuel and two up the back will sit a fair bit if you have sensible springrates.
