Hi there, just looking at filling out my iva forms AGAIN! I filled the first set out in 2010 and never did get to test
The bits I'm stuck on are
Section 4 vehicle details original design laden weights of the vehicle -
Previously I had put
Axle 1 450kg
Axle 2 450kg
Gross 900kg
Train and towable mass I had left blank?
Is the above correct for an Indy?
The other question is
What is the engine maximum power AND the engine speed at which it is obtained?
My engine is an injected 06 R1, previously I had written 172bhp @11000rpm
Would this be ok as I believe they use these figures for the noise test?
The last question, engine size? Mines a 1000cc so I had previously written 998cm3, is this correct?
[Edited on 24/7/13 by corrado vr6]
regarding weight yes.. leave all the others blank
it too googled my gsxr 1000 details and put down the same as you although you'll need a haynes manual for iva or i was asked for one at mine for
engine spec info..
wikipedia search for your engine..
180 hp (130 kW), 128.7 kW (172.6 hp) @ 12,500 rpm[18]
998cc would be correct...
hope that helps..
[Edited on 24/7/13 by doobrychat]
Spot on, cheers mate
it too googled my gsxr 1000 details and put down the same as you although you'll need a haynes manual for iva or i was asked for one at mine for engine spec info..
hope that helps..
If you go too far they wont be fooled though so don't be
tempted to put 8000.
