Does the IVA man expect a build diary and detailed photos and if so what am I expected to put in it? I couldn't see anything in the manual about this but have heard people mention it in passing. Is it definitely required? Any examples I could follow?
I dont think its a specfic requirement, but its in case theres any places he cannot see (ie a fully enclosed riveted tunnel) just to prove you have
secured the pipes, loom etc adequately.
I think its more for the DVLA that the photos are useful, to prove the stripped parts of your donor were removed from the donor, and that you made the
car (to declare as an amatuer build).
For example an imported car would not have a build diary, but would still require IVA to be registered.
[Edited on 20-8-13 by loggyboy]
Ah - so is it actually for registration the diary is needed? Do you know where the guidance is to show me what I'm supposed to be keeping?
I am going for a new reg, so want to keep myself right!
I took a disc of photos to my IVA test, they were never asked for.
I included a disc full of build photos for the DVLA application, the CD was returned un-opened as I had sealed the case on purpose.
In terms of Pics, do you really need to be in the pictures themselves?
I bought my kit part built so only have a receipt for that and someone else finished it off for me!?!?
Will I have problems with the pics I have with me not in them?
I also sent photos off on CD and printed and no idea if they looked at them
However I took the printed ones with me to the IVA test itself where they came in handy to show the tester the mounting points for the seatbelts in
the tunnel and how they were welded etc. Otherwise might have meant pulling more panels off.
So if you have photos of any inaccessible welds or mounts then might not be a bad idea.
Rich
