Hi All
OK, it's official, I'm a failure.
Four items to fix then hopefully it's a pass.
1/
My demister sucks air the from inside the engine bay.
The fix is to block off with a duct that will mate with the underside of the bonnet.
Louvres in the bonnet and jobs a good un.
2/
Brakes need an overhaul. Generally out of balance.
New seals were used when I fitted them but lack of use has made them stiff, some more than others.
A pre MOT would have shown this up. New seals all round and new fluid followed with a rolling road check.
3/
Fog light wired wrong.
Needs to only work with headlights and not work with side lights. Rewire.
4/
My side repeaters failed the 5 deg from the rear visibility test. Obscured by rear wheel arch.
Dennis the tester said, " You have obviously gone to a great deal of trouble to find and fit these. They would have
passed SVA but I've got to fail them." ( see pic )
I'm now looking for a pair of mirrors that have repeaters incorporated and are viewable from behind.
Not the type fitted to bikes that are front indicators and viewable from the front only.
Any help with this would be much appreciated.
Blew a 5a fuse. Pinched a 20a from the tin top.
Headlight out of alinement, adjusted with Dennis's help. ( up a bit, right a bit, that'll do )
It was a long day. Set the alarm for 4.45 woke at 3.15 Set off at 5.45 and arrived at 7.55
By the time everything was put away it was 5pm. A meal, a wash, and in bed at 9.
Knackered, but a grand day out, and a "good fail".
Cheers All
Paul G
Passes SVA but fails IVA
As failure lists go, that's a very short one!
That's a good result, if a fail can be good - not a lot to get sorted.
Well done!
Bad luck Paul, would have been nice to pass first time but at least they are all easy fixes. Mel
Mine passed SVA with the heater intake inside the engine bay and the repeaters exactly where yours are
My repeaters are also in a similar position, although they do stick out a bit further than Paul's. From what I can pick up, I think the tester
would have liked to have passed them, if he could. He sounds as though he was sympathetic.
As for the rest - brakes out of balance, fair enough, just unfortunate that they'd sat around for ages. Fog light, fair enough, just an easy
re-wire. Demist from the engine bay - I can't comment, I don't have demist! I think I'd prefer that it came from outside, but
that's just personal preference anyway.
Probably worth finding out why that fuse went - may be a potential fault, or just a too-small fuse.
[Edited on 14/2/15 by David Jenkins]
Not too bad at all
Surely the demister taking in air from under the bonnet should not fail on a car with no roof?
I can understand the reasoning for a car with a roof, fumes etc.
Indicator position and fog light wiring have been discussed a lot on here
If your planning on using the side in indicators on scuttle once it's passed test you will need to remove them from the car and put a grommet in
the hole for the retest.
Originally posted by 907
Hi All
OK, it's official, I'm a failure.![]()
Nice short list.
Shame about the side repeaters as they look great. I think the rear arches are the location that's been found to pass best. If you fit another
set to pass then you'll have to blank those off somehow as you're only allowed one set of side repeaters. Don't think just removing the
bulbs will pass unless the wiring is also removed.
Originally posted by CosKev3
Not too bad at all![]()
Indicator position and fog light wiring have been discussed a lot on here![]()
If your planning on using the side in indicators on scuttle once it's passed test you will need to remove them from the car and put a grommet in the hole for the retest.
Would it be possible to drill the outside edge of the mirror housing and fit small round repeater. i thought that CBS used to sell mirrors with side repeaters.
I thought they could only test what is fitted on the day?
If they could fail them on things you could change after test not many people would pass the test!!
Standard steering wheels/big ugly shields over exhausts/extensions on front indicators etc.
Or fashion an offstand for the repeater? An offstand that may fall off in the near future.
You are certainly not a failure Paul. Your car is a work of art. beautifully crafted, well engineered and one that anyone would have been proud to
have built.
Thank you for the heads up on wiring the rear fog light. I would have done exactly the same as you and wired it through the side lights. I'm in
the middle of wiring my car now so still time to change it.
As for the other items; all trivial and easily rectified. I'd say, a good result Paul.
I have seen the small round repeaters fitted to the headlight bowl or the outer edge of the front wing
I think youve done good there.
When U IVA mine Im going to get an mot station to go over it.
I like the indicator detail.
If you remove the scuttle mounted indicators for the iva retest, I have some brushed stainless steel effect offcuts that are about 0.80mm thick at
work, I could send you some so that you could loosen the windscreen supports, push these behind to cover the triangle hole & then re tighten the
windscreen supports to hold in position.
Drop me a u2u if you are interested, it's from some heavy duty equipment labels that we use at work, I don't think it will even notice &
you can put back how it was afterwards without too much hassle.
I can pop a couple of bits in the post for you.
[Edited on 14/2/15 by Andybarbet]
Thank you very much for the offer Andy.
I do have some 0.9 that will do the job.
So what do we think of these?
http://www.carbuildersolutions.com/uk/stick-on-amber-led-indicator-pair-leda9
Fit them down the outside edge and round to the underside of the mirror.
Wire would almost be hidden under the mirror.
After IVA I would like a pair of ally bullet shape race mirrors (convex) as they would be in keeping with the car.
I'm sure the present mirrors will find a home.
Paul G
I'd be worried about type approval - the one advantage of fitting lights with approval marks is that the tester can't complain about the light itself, only about where it's fitted.
This is assuming that those lights haven't got an approval mark, of course.
Oops - just noticed that they are marked E11 - so the only issue would be whether your indicator circuit would work OK with a LED light in circuit. Probably get away with a load resistor somewhere though.
I wonder what the sidewards visibility would be like if mounted the way you suggest...
Would those lights be seen as being a permanent fitting Paul ?
Possibly not Mel, but nothing was said about the interior mirror held in place with mounting tape.
I have a mix of led & bulbs so I think that led repeaters wouldn't be a problem David.
No hollow stems AA. No such luck.
To be honest I can't get my head round the need for a side indicator to be seen from the rear (almost) of the car.
From the point that Dennis (the tester) marked on the floor the view of the side repeater was blocked by the rear arch,
but on that very arch is the rear light unit, part of which is the rear indicator.
The indicator is blocked by the indicator. (shrug)
The other thing that puzzles me is that for IVA the view is predominately from the rear.
Side repeaters on production cars are viewable predominantly from the front.
Still, if a hoop is held up I suppose we must jump though it.
If anyone spots a production car with mirrors that would pass please let me know.
I've got a feeling the price would be ott though.
Paul G
p.s. thanks for the complements btw.
Digging into IVA manual Part 23 Direction Indicators.
Note 3 of the Method of inspection states:
TextNote 3: In addition, on M1 vehicles less than 6 m in length,
side-marker lamps may be used, if they supplement the angles
of visibility requirements of front indicator lamps or rear
indicator lamps where the obligatory lamps do not meet.
So to the letter: M1 Vehicles are not Mandatory .
Side repeaters are optional.
Unless my understanding of english is different to yours. Then: If you don´t install Side Repeaters, you don´t need to comply with thee "Required
Standard"
Bear (Sp?) with me as english is my second language and when I say english I mean "Colonies" english.
Regards
Angel Acevedo
What the hell with my connection??
I have to send reply twice..
Just after typing....
JJJ...
I came up with my previous post after reading IVA Pass Sheet from Rob55
http://www.locostbuilders.co.uk/forum/23/viewthread.php?tid=185399&page=3
Where it states wheelbase 2320 mm....
According to IVA Side Repeaters MUST be within 2600 mm from front of vehicle....
So to the letter the rear archs might be a good place to place repeaters...
If you want....
If not abide by Note 3 as in my previous post....
Food for thought.
AA
Hi AA
I think that it's down to how you interpret the wording.
Side markers I would say are constant lights, i.e. not flashing. I have them down the side of my trailer.
Repeaters are part of the indicator / hazard lights, and are mandatory, but only one each side.
I'm sure Dennis the tester would have said if removal was an option.
I did know of the 2600mm measurement as I did at one stage consider putting repeaters on the roll bar uprights.
I already have wires inside it feeding a high level brake light.
Again my interpretation, but I would say measuring from the front of the car is the point on the front of my nose,
which means 2600mm comes to the front of the seat wings, well short of the rear arches. ( see pic )
Thank you anyway for your help, and indeed everyone that has contributed to this thread.
Paul G
repeaters to be within 2600mm
Caterham, GBS and Westfield are using the side repeaters on the front wing.
Back in the days when I owned bikes the fashion was to not have mudguards but to have a "hugger" fitted.
Well, that's what I've got on the car.
With 10mm of clearance I thought that aesthetics and aerodynamics are more important than having room
to run wires. Just got to avoid gravel drives.
Paul G
Well, twin wires are only about 3mm thick at their narrowest!
And, after all, they only have to be 'safe and legal' for a few hours...
That car looks epic!
I'd just sit staring at it if it was in my garage,and get nothing done at all!
Well, twin wires are only about 3mm thick at their narrowest!![]()
And, after all, they only have to be 'safe and legal' for a few hours...![]()
I'm sure that you could fabricate a bit of aluminium to cover the wire!
[Edited on 15/2/15 by David Jenkins]
I'm sure that you could fabricate a bit of aluminium to cover the wire!![]()
I've got a pair if you want them Paul , I can take them to work (between Thaxted and Saffron Walden) if it's any help
I've ordered those flexy led strips from CBS now Mel, thanks all the same.
I'm chained to the workshop anyway this week, finishing off a job for JLR.
I worked today to make up for Friday's IVA trip. O the joys of self employment.
Paul G
Paul G
Looks good mate. I hadn't thought of mounting them low & facing back.
Good luck for your IVA.
Paul G
Lovely car. I wish i had those skills. With regards to the flexi repeater strips, I fitted mine as shown in this image. I'll let you know how I get on. Tests in a week.![]()
Oops
[Edited on 15/2/15 by ctwv50]
@ Dick
Windscreen supports cut from 3mm sheet ally. (not strips welded together). Paul G
Position-wise, those'll be fine - I have an email from VOSA's policy department to that effect, and its where mine are.
@ Dick
Thanks for that bit of info. Gives me more confidence in my 6mm thick stanchions.
The top part of my triangle falls on the 125 rad of the scuttle, and then I needed a sharp crease. (see pic)
This wasn't the easiest shape to form in 3mm. I would imagine 6 will be harder to shape.
Hi All
1/
Hi All
1/
I got a chance to make a start on the IVA fail items this weekend and hopefully item 1 is now sorted.
I even got a start on the repeaters. Will post a pic of them when finished.
Paul G
Lovely work Paul, as usual!
Just a thought - have you put a little drain at the bottom of that box?
Hi All.
The LED strip repeaters are now fitted.
The long wire run discouraged me from fitting them to the front mudguards, plus I desperately need to avoid drilling
holes that may become redundant at a later date.
Instead of the Mitsy windscreen mount triangle location why not just block off and mount a little higher, so that's what I've done.
I hate them with a passion, but if this is what it takes to pass then I'll just put up with them. (for a while)
No aluminium has been harmed in any way in the fitting of this item.
If anyone says they look nice I'll follow them home and shat in their slippers.
Paul G
Temporary repeater location
Arghh my eyes!
Don't you just love ruining your car for the IVA man.
[Edited on 23/2/15 by ctwv50]
Paul,
How are you going to fix the wire, so it doesn't flap around and get caught by something?
Paul,
Sounds plausible - it's just that if it looks temporary then the tester may think you're extracting the urine. I know I maybe sounding a
bit negative, but I want you to pass next time you go!
Regarding the double-sided tape - I reckon the rule about using it relates to fixing the light unit, not the wire (but I may well be wrong). As for
shifting the glue, I find that "Sticky Stuff Remover" is excellent in shifting most tape glues! Failing that acetone, meths, brake cleaner
or panel wipe have always been good fall-backs for me.
[Edited on 24/2/15 by David Jenkins]
Could you tuck the wire behind the windscreen support? So it looks less stuck on?
I was thinking about some form of capping - had a quick look around the web pages of various suppliers, but didn't find anything obvious.
I could drill an 11mm hole in the windscreen support, fit a grommet, and pass the wire through and down
the inside edge against the screen, then drill another 11mm through the scuttle.
However, I'm trying to avoid doing anything that can't be restored to how it needs to be to pass future MOT's,
if you get my drift.
It's for similar reasons that I don't like the repeaters fitted to the front cycle wings.
That to me doesn't seem a good place to fit them as they then shine in the drivers eyes, which is exactly why
production cars (Honda/Merc/VAG and others) that fit them in the mirrors face them forwards.
You certainly can't see 50% of the lit area from 5% out from the rear on the Octavia parked next door.
Paul G
How far back do they stand from car when checking the 5 degrees viewing angle to side repeater?
I was musing over this last night - probably too late now to anything different - but I was wondering about a little stalk up and out from the
existing triangle where the old indicator was (and where the future indicator will be!
). Tubular stalk, wires up the middle, some appropriate
light fitting at the end. Easy to fit through the existing hole, and easy to remove later.
Apart from that flight of fancy, I was wondering if a bit of ali capping would cover the wire and make it look 'permanent', e.g. in bad
ASCII art __|--|__ stuck on with double-sided tape. The tape I've got (made for fixing trim to car bodies) is amazingly tough stuff, but can be
removed without damage - you're welcome to a length of it, if you need it. Either this, or a bit of narrow D-profile trim that would take the
wires inside.
He dropped a line down from the repeater. Chalk mark.
He laid his extended tape measure on the floor level with the car side and out past the back of the car.
( this was inside the rear tyre )
He had previously worked out ( by trig ) what 5deg was at the end of his tape so measured out out with another tape
and put a cross on the floor with his chalk.
He measured the height of my repeater ( 600mm ) and went back to the cross, got down on hands & knees,
and with his eyes at 600mm above the floor looked at my repeater.
The view was just blocked by the edge of my rear arch.
( It's worth pointing out that from this position your staring at the rear indicator on the rear arch. )
My theory is that the windscreen supports are 900mm high so his sight line will now be above the wheel arch.
The distance back doesn't make a difference as 5deg is 5deg at any distance.
Hope my rambles are understandable.
Paul G
Edit to add pic
[Edited on 25/2/15 by 907]
Do indicator lights have to be e marked like the headlights and rears?
as I doubt the led's are
Personly I would of put a light in the mirrors
steve
I fitted my side repeaters to the rear arch. I used the tiny button LED's without the rubber surround, and easy to wire from the rear indicators
steve
steve
I was musing over this last night - probably too late now to anything different - but I was wondering about a little stalk up and out from the existing triangle where the old indicator was (and where the future indicator will be!). Tubular stalk, wires up the middle, some appropriate light fitting at the end. Easy to fit through the existing hole, and easy to remove later.
Apart from that flight of fancy, I was wondering if a bit of ali capping would cover the wire and make it look 'permanent', e.g. in bad ASCII art __|--|__ stuck on with double-sided tape. The tape I've got (made for fixing trim to car bodies) is amazingly tough stuff, but can be removed without damage - you're welcome to a length of it, if you need it. Either this, or a bit of narrow D-profile trim that would take the wires inside.
Originally posted by 40inches
I fitted my side repeaters to the rear arch. I used the tiny button LED's without the rubber surround, and easy to wire from the rear indicators![]()
steve
That would fail as on my car it's more than 2600mm from the front of the car. see previous post
Cheers anyway
Paul G
Paul G
Edit to add pic
Cheers anyway
Paul G
Is the MK shorter than a Locost? The photo is pre IVA and it passed on measurements.
Cheers anyway
Paul G
I don't know where 2600mm would come to on an MK.
My chassis is the same length as a Locost but my pointy nose could be longer as it's a bit of a one off.
Paul G
Cheers anyway
Paul G
Paul G
Paul G
Edit to add pic
5 degrees is 5 degress yeah, but if your rear arch gets in the way the distance they stand away makes a difference.
Some people on here have said testers go to ground level, so if they did that say a foot from your rear arch you wouldn't be able to see your side repeaters at 5 degrees would you?
Paul G
Paul G
Edit to add pic
There's a vertical angle as well. Depending on the height of the light, if it's over 750mm then it needs to be visible 15 degrees below horizontal, otherwise, 5 degrees below. That will determine where he takes his sight line from.
Should be able to test it fairly easy in the garage.
It needs to be visible within an arc.
For high mounted lights (above 750mm) it's the blue line;
from 15 deg above (looking down) to 15 deg below (looking up)
For low mounts (red sight line) then its still the same 15 deg looking down, but only 5 deg if you look up at the light.
I've just been out to pick up some metal for a work job and I'm finding that every car I pass coming towards me
that has repeaters in its mirrors I'm calling the driver names under my breath.
I passed a parked one that had it's mirrors folded in and you could see them from all angles.
Paul G
Ah yes - the old game of "spot the bits of factory-made cars that wouldn't pass IVA in a million years!"
Or did you mean "I wonder if I can fit a pair of those mirrors on my car?"
[Edited on 26/2/15 by David Jenkins]
The trailer marker lights arrived today so I've managed to get one side fitted.
Needs a blob ( I can do blobs ) of paint to cover the Araldite fillets but otherwise done.
The wire comes out of the mirror case and runs underneath the mirror stem and doesn't really notice.
Wadderwethink ?
Paul G
Should look very tidy once the 'blob of paint' is done! It also will look like you intend it to be permanent, which should please the
tester.
BTW: I now have a 3D printer, so if you give me the dimensions then maybe I can make a plastic surround to finish it off. No hard-and-fast promises
as 3D printing can be very frustrating, but I can't see that they would cause much difficulty. Alternatively, get a bit of black plastic from
Gaz and turn it on your lathe?
Mind you - it depends how permanent this arrangement is going to be!
[Edited on 27/2/15 by David Jenkins]
Quote. Mind you - it depends how permanent this arrangement is going to be. End quote
Days…….Hours……. maybe only minutes.
The final purchase will be a pair of aluminium bullet racing mirrors. I'm that age.
They ( IMHO ) will be a fitting addition and will match perfectly.
Unfortunately the repeaters, along with the plastic mirrors, will also have to take their chance on eBay
so I'll just have to make do with the Mitsy ones. Shame.
Paul G
Just to let peeps know I passed with my side repeaters in that location.
edit: I mean on the rear of the front cycle wings.
[Edited on 18/3/15 by ctwv50]
