Well, it failed at Nottingham. But only just, If I had taken my laptop I might of been able to bodge it enough to get it through but I would of most
likely made it worse...
The long and short of it, it failed on emissions. There were 4 other things that i was able to rectify whilst there, but not the emissions.
1: Brake fluid light wasn’t coming on with the float switch. Pulled a wire out when fitting the bottom dash panel. SORTED
2: Wing mirror mount not 2.5mm... filed the edges, just needs painting. SORTED
3: Fog light coming on with the side light. Moved feed from side lights (Tigers loom) to main. SORTED
4: Rollcage mounts not 2.5mm (only just) filed edge. SORTED
I have spoken to rich at GBS (they are the closest emerald agent, plus I know them). I now need to check my shift pattern and the next available
re-test and then get it over to get the MAP sorted.
All in all I’m chuffed to only have 1 thing to sort out. Even if it is a biggy.
Congratulations, at least you have only this last step to complete now! If I get to IVA and leave with only 1 thing to sort I will be over the
moon!!
The epoxied cable bases didn't raise any comment then?
That's a bit of a bugger!
At least you only have the emissions to sort. Fingers crossed the re-map can sort it out.
Have a word down at the local VW / Audi garage, someone there might be able to set it up for when it's stationary / undergoing IVA / MOT
testing...
Originally posted by jps
Congratulations, at least you have only this last step to complete now! If I get to IVA and leave with only 1 thing to sort I will be over the moon!!
My Stack speedo self calibrates from pulses over a 2 mile distance, obviously this is
effected by circumferences, pick up position, tyre pressures, amount of pulses etc etc. Just used a little maths and common sense in the end. I failed my first time round as well. Seems like easyish fix so hopefully a pass next time. I was really surprised how helpful and encouraging the IVA testers were at Nottingham. Took the time to explain everything and how I should go about fixing stuff. They even pointed out some stuff that I should change but were not fails. Bunch of really helpful chaps
Well done, so close and hopefully an easy fix.
Nice one! Hope you get the emissions sorted. Hopefully you'll get some proper sun when you've got it on the road!
well done, i would be more than happy with that list! I had a nightmare with my IVA, so well done!
I’m in the process of sorting the emissions set up and retest. My exhaust Db were 94 so a good pass, I did notice however an ocassiinal puff from around the collector and cat so I could possibly have an exhaust leek? It could of been steam/smoke from the wrap or the tape around the lambda boss, is it worth striping it all off and checking and re sealing the system. I really don’t want to but if it’s going to screw the emissions up I might have too???
Ah so close! Damn good fail though, fair play.
Worth making sure the exhaust us sealed properly, a leak could indeed throw off the emissions.
Is the wide band working correctly? With this set up it should sail through the emissions, does it share a common earth with the ECU?
It's a nice feeling though knowing you have a set list to work to a and then you're on the road!
[Edited on 4/4/18 by Daf]
I have my re-test booked for the 9th of may...
I'm trying to get my emmisions sorted, Rich at GBS is going to help get it set up and show me a couple of bits in the map to tweek if needed at
the re-test
There's a few bits I've dicided to sort and change to help get everything in line...The big unknown are my TB's, although everythings
spaced to suit and it runs, there's just a few things that I haven't got enough time or knowledge to sort out. I don't know the cc of
the injectors, hours of searching brings up sizes anywhere from 200cc - 410cc... They are currently set at 270cc as this is the most common size thats
stated in everything I've read.
My balanceing isn't quite right either, the tiniest adjustment to any of the screws messes everything up very quickly. I can't get Cyl 1
to drop any lower than about 7CFM where as the other 3 are all at 4.5-5 CFM on tickover.
No matter what I've done I just can't get them set correctly. I think my exhaust is also blowing slightly at the collector so that needs
to get re-sealed.
The long and short of it is I've ordered some new TB's from DanST that are spaced balanced and a known 240cc injector size. I'm sure my
current TB's are fine. I'd just prefer to start with a known set up rather than guessing things and failing IVA again.
I've stripped the exhaust off as well ready to get the Gum Gum crap off and get it re assembled properly.
This should get me alot closer to GBS being able to sort things out fairly easily... Fingers crossed
So I’m now 2 days away from my re test. I’ve stripped and re sealed the entire exhaust, replaced my TB’s with a new set from DanST. These are balanced
and 240cc injectors and fired up first time with no issues, just a slightly higher idle RPM.
I’ve re loaded a known ok map and made a few adjustments ready for the emmisions setting before the test on Wednesday
TPS reset,
Injectors scaled,
map set to open,
hopefully everythings ok and we can get it close enough to pass. If I can’t get it on tuesday I’ll have to cancel the re test and get it booked in for
a proper mapping session and RR.
Very best of luck for Tuesday !
Got them crossed for you !
