I know my gsxr1100 engine will have to pass the new emissions regs on its SVA test, but as far as I know it has no catalytic converter - do I need to
add one? If so anyone have any suggestions where to get hold of one?
Or do bike engines manage to get by without?
James
If the engine age is 1st August 1995 onwards, then it will require a CAT test. Most kit manufacturers will rent-a-cat for SVA purposes.
You could try These people in the states
got one last week for my Zetec install.
This is no kit, it's a scratch build
Design as so
The engine is a '96 i believe, so it will need a CAT?
James
thanks BKLOCO, they look like the jobbies if I need one
Scratch built or not, they'll still rent you a CAT.
Are those wheels real??
no all 3D - and i've yet to add lights, indicators, mudguards etc. It was originally designed as an offroad toy, but the thought of 450bhp/ton on
tarmac proved too tempting so I'm now building it in mind of getting it SVA'd at some point
James
It looks almost real, parked up on your drive like that. Just a bit too much grey and black.
It looks quite neat, good luck with it.
Originally posted by cloudy
no all 3D - and i've yet to add lights, indicators, mudguards etc. It was originally designed as an offroad toy, but the thought of 450bhp/ton on tarmac proved too tempting so I'm now building it in mind of getting it SVA'd at some point
James
you have U2U NS Dev
ive just bought my indy blade (built)!! its a 98 blade engine and has no cat on it,
ive got the old MOTs etc, the mot is up in June, will i have to put a cat on with the new regulations
What year number plate does it have?
its on a Q plate
Tested on visual smoke only - No Cat required.
[Edited on 24-2-06 by Hellfire]
thanks, one thing less to worry about. ha
