is this ok for sva, (hydro clutch)
FlansS14 - 2/3/07 at 12:50 PM
http://s13.photobucket.com/albums/a282/FlansS14/?action=view&current=CLUTCH.jpg
Is this ok for sva, its for a hydro clutch. basicaly from the master cylinder i have made a 180deg. copper pipe that connects to a flexi hose that goes to the slave cylinder.
also does it need a low fluid indicator
Howlor - 2/3/07 at 12:53 PM
The SVA would not really cover anything like this I think.
mookaloid - 2/3/07 at 12:54 PM
I would secure the free end of the copper pipe with a bracket so it doesn't vibrate, but otherwise ok
You don't need a low fluid level warning for the clutch.
Mark
02GF74 - 2/3/07 at 01:00 PM
as used on land rovers since the year dot. no probes with that at all - but as said, ensure the pipe is secured as you would for brakes and that the hose is secured on chassis/gearbox. (land rover have a small length of pipe from slave to hose )
iank - 2/3/07 at 01:06 PM
Exactly the same as a classic mini arrangement. The junction of the copper pipe and the flex hose is through a bracket attached to the bulkhead.
Peteff - 2/3/07 at 01:53 PM
The verto clutch setup on a mini has a reducer in the clutch piping to increase pressure and will not work without it if I remember right.
