Hi,
Does anyone know the rules (for the SVA) in respect of 4 point harnesses.
Would this sort of thing:-
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=014&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=330173650281&rd=1
be OK to use?
Thanks,
Id say No as they dont say that there is an e-mark on them.
Correct buckle style though.
regards
Agriv8
Think I paid about 90 quid for a new pair from MAC#1 about 2 years ago.
For that sort of money is it worth risking your life???
James
£90 ish delivered for a set of Sabelt 4 point harnesses from Lolocost. Correctly marked for SVA, correct buckle type and supplied with mounting
bolts.
Don't skimp on this kind of thing!
I've got a set of sabelt 4 points for sale, £45 as they don't have the mounting bolts.
Thanks for the replys,
I asked the seller and these are not e marked.
Basically then they need to be:-
e marked
Have a particular sort of buckle
Come with mounting bolts
Looks like I will save up and look out for a branded set that meet these requirements.
Can anyone recomend a supplier to use?
Thanks,
Try www.s-v-c.co.uk Seem to have a good supply of most stuff. Also, the guys are very helpful
David,
The ones chokymonster is selling will be ideal for you. The bolts are nothing special - an imperial fine thread IIRC and available for a few quid
from a good nut and bolt supplier. Although you will need the little stepped spacers that the bolts sit in.
U2U sent to Chockymonster,
Thanks for the help,
