If i was to get these mirrors
clicky
Would they replace the standard side repeater for SVA?
Ben
they look really smart and fairly cheap too, think they should pass ok. as long as they've got enough rear vision and haven;t got a sharp surround.
by the looks of them,no,the repeater needs to be seen from most places along the side, looks like you can only see them from the front
I doubt they would pass I'm afraid. Side repeaters are to be viewed from the read / side not front / side.
See here for wotsit.
Light Angles
You might be able to use them as the front indicators though?
Mike
Cheers chaps, thought it might depend on angles.
really should get a copy of the SVA manual at some point lol
I agree, I don't think they would pass either. I have a pair of similar mirrors on the Phoenix but I also fitted additional repeaters to the side
of the car.
WARNING
The SVA tester came very close to failing my car because of the number of indicator lights. In addition to the mirror indicators I also had a pair
near the headlights. And then there were the repeaters... He let it go but it was close. I had not realised that you could have too many
indicators.
Just thought I'd pass this on. Hope it helps.
John.jpg)
You could have the mirror lights permanently lit if they only show to the front, like the trailer side marker lights on artics for the SVA purposes.
I sell similar units (quite a bit cheaper!)
, but I always recommend them to be in addition to existing side repeaters.
more importantly... I would very much doubt whether those mirrors meet the size/shape requirements for SVA as they are an unusual shape... I would check first!
is there mention in SVA manual about side repeater lamp wattage?
i.e. could a couple of orange LED's be used?
There is no mention regarding wattage of any lights afaik. I have used LEDs on all of my lights (except headlights) and Mr SVA loved them. As long as
they are deemed to be 'of sufficient brightness' they should pass - even a 21W indicator bulb can fail if the reflector is inneffective or
even too effective (ask Flak about that one
