im dooing my sva forms and q11 asks what date was made or first reg
im hoping to get new reg so if i put todays date will it go on a 08 plate
or will it go on 58 if i reg it after aug
thanks
Is your car made of ALL new parts then with the exception of 1?
Check out the sticky post at the top of this forum
[Edited on 19/6/08 by ReMan]
You will need to wait till Sept 1 st for 58 plate.
Although I am submitting mine so will read responses with interest
Regards
Bob
If it is "new" i.e. all new except for one part, then I think you can get a 58 plate if first reg after 1 September even if (obviously) built beforehand
I put "New build". I got an '08.
adrian
adithop did you put that in q11 on the sva form
adrian
Can I take the "fifth amendment" on that one?
The rule says... All major components except one which can be "reconditioned as new".
Chassis, steering, axles (hubs), engine, transmission (diff and prop shaft) are listed on the form (can't remember the form number). I have
reciepts for them all being new except the engine and I've one for that being recon'ed as new. DVLA also asked me to sign a declaration of
newness. I also made sure she saw the file of bills when they did the inspection but she wasn't inclined to wade through it!
adrian
Yes, I put "new build" for q11 on the sva form.
adrian
so did i and i got my 08 plate details through yesterday
Is the question around the reg more to do with when you apply to DVLA for your plates as against when your original build date is.
Ricky
