hi all, does the underside of the dash need to be covered up or can it be left open?
thanks
stuart
Lower dash edge has to be radiused (19mm). The area behind that is covered by the normal contactable sharp edges rules. They don't want you
cutting your legs off in a shunt!
Its simpler to put something under there. I put some carpet under held in by velcro and had no problems. They had a good look despite it being harder
to check under there on the Fury than a 7.
adrian
I didn't panel under mine and it passed. There wasn't anything to contact though.
