Do any of you chaps have a TPS account? I need a complete set of engine mounts for my 2001 polo and given how expensive they are from VW main dealers... was wondering if TPS would be cheaper?
Trade discounts aren't that great with Tps unless you spend a lot with them , you can buy over the counter so no need for an account . Usually 20% cheaper than main agent vag.
I had a search online that suggested only some TPS stores allow public to buy... the Plymouth one apparently does not! :s
TPS is owed by VAG anyway.why not try aftermarket say though GSF or Euro Car parts there stuff is just as good.
Things like engine mounts and suspnsion bushes I'm not sure the generic stuff is really as good. Hears bad things. Am I just being paranoid?
Most of gsf stuff mount wise is febi and if you look closely you will fine where the vw badge is ground out. as said not as yet had a problem with it but guess others have.
Hi I work for a German car specialist and we have an account with tps send me a message with what you want and the last seven digit from your chassis no and I'll price the parts for you
