Acewell and IVA
40inches - 29/4/13 at 01:23 PM
Anyone been through IVA with this? Did it pass, or did the Mode button have to be covered?
Wheel fitted
Wheel fitted
wylliezx9r - 29/4/13 at 03:19 PM
Isn't it located within the exempt zone of the steering wheel anyway ?
Dangle_kt - 29/4/13 at 03:35 PM
its not the radius that is the issue - its if the speedo can be changed to KPH, or turned off I think...
I dont know the answer, just clearing up the question.
Looks good by the way.
gavin174 - 29/4/13 at 03:44 PM
I made up a little plate that i could rivet/stick over the buttons at the test centre if required...
it was never mentioned.
IVA 3 years ago
gdp66 - 29/4/13 at 04:52 PM
I had a plate I was going to 'glue' over the buttons.
I switched through the modes, but he didn't notice it stopped showing the speedo.
take a plate/cover and hope he doesn't ask or press them.
I think the later acewells switch back to a speedo once you start moving.
40inches - 29/4/13 at 05:08 PM
Thanks chaps. I think I,ll make a cover plate for my "just in case" supply.
Andybarbet - 29/4/13 at 05:25 PM
I have the same digidash but was curious as to what extra gauges you have fitted ?
I was thinking of doing the same & using the digidash mainly for the speedo & rev counter.
40inches - 29/4/13 at 06:19 PM
Oil pressure, water temp and volts. Fuel gauge on Acewell
