Author: Subject: Vosa and reciepts
omega 24 v6
posted on 23/12/08 at 03:08 PM Reply With Quote
Vosa and reciepts
Just about ready to send of the old forms/piccies and reciepts (copies).
Some of you have been speaking about having to sign/validate the reciepts as copies of originals.
What have you written on the? is it just a case of "I joe bloggs certify this as a copy of the original" or something different.?
afj
posted on 23/12/08 at 03:25 PM Reply With Quote
i wrote 'certified copy' and signed them
omega 24 v6
posted on 23/12/08 at 03:27 PM Reply With Quote
And was that good enough for them (have you been to /passed sva?)
russbost
posted on 23/12/08 at 03:50 PM Reply With Quote
Just write "certified copy" & then sign - I've just been for SVA & they were fine with that. They only want receipts for major items ie donor vehicle or engine/gearbox/axle, kit chassis or steel receipts, bodywork, wheels, maybe dash, fuel tank,steering wheel, but not every nut bolt & washer
omega 24 v6
posted on 23/12/08 at 04:02 PM Reply With Quote
OK cheers lads
Danozeman
posted on 23/12/08 at 05:26 PM Reply With Quote
They sent me a letter saying i had to put "certified copy" on them and sign them when i did mine because i had just sent copies of reciepts without signing them as i didnt know you had to.
Make sure you do them all.
Dan
cloudy
posted on 23/12/08 at 05:33 PM Reply With Quote
Here's my stupid post of the day - Is this for SVA application or DVLA registration. This is different to the receipts required for a new reg?
James
russbost
posted on 23/12/08 at 06:57 PM Reply With Quote
James, this is for SVA, they now ask for receipts as proof of amateur build, you'll need them again for DVLA I believe.
cloudy
posted on 23/12/08 at 07:24 PM Reply With Quote
Thanks Russ, building is the easy bit for me - the paperwork just baffles
[Edited on 23/12/08 by cloudy]
www.warnercars.com
omega 24 v6
posted on 23/12/08 at 08:46 PM Reply With Quote
Yep sva. DVLA have already had them.
Nice to see our hard earned taxes go to bodies who work together NOT
macca1
posted on 23/12/08 at 10:35 PM Reply With Quote
Sorry to jump on your thread, but where would you stand if your bought an unfinished build(yes I have) and only have a single receipt for the whole thing, is this going to cause me a massive headache?
Col
mistergrumpy
posted on 23/12/08 at 10:37 PM Reply With Quote
There is a section on the SVA paperwork asking if yours is, basically a part self build i.e. someone else built some. I can't remember the exact wording but I would presume you ticked this option rather than the complete self build option. I would then presume that they would accept that you wouldn't have all receipts.
russbost
posted on 24/12/08 at 11:41 AM Reply With Quote
Macca
One important point is that the big difference between amateur built & pro is that all pro builds have the Cat test irrelevant of engine age - if you have a post '95 engine you'll be Cat tested anyway so it doesn't really matter.If you have an earlier engine & want to avoid the Cat test then it all comes down to being able to prove the whole car has been amateur built, if the project you bought came with a load of build pics which are obviously in an ordinary household garage rather than a pucca workshop then your fine as long as you take more pics along the way, if you've not got this proof you need receipts for either chassis or steel to build it, a donor car or separate receipts for eng/gearbox/axle etc, wheels, seats, fuel tank, brake lines etc - they don't want every receipt - I provided them with about 15 which they were happy with, but they want receipts for the major items or pics to prove amateur build status. HTH
