Author: Subject: Reverse Box / Lever
spdpug98
posted on 27/2/09 at 09:33 AM Reply With Quote
Reverse Box / Lever
Does the centre tunnel fall within the radius test area, I have a reverse box fitted and am unsure whether to fit the arm / lever through the tunnel before the SVA or after.
My Blog: http://spdpug98.wordpress.com/
Mr Whippy
posted on 27/2/09 at 09:36 AM Reply With Quote
think it does, but if you put a ball type knob on the end how could it fail, its just like the gearlever
spdpug98
posted on 27/2/09 at 09:51 AM Reply With Quote
I didn't want a ball type top I wanted a 'T' shaped style lever, the main shaft of the lever will just be flat section ali so was worried about the radius of the edges etc
Maybe I should just fit afterwards
designer
posted on 27/2/09 at 10:04 AM Reply With Quote
Why not change the knob after?
spdpug98
posted on 27/2/09 at 10:20 AM Reply With Quote
I could do, but not sure how I would fit a ball to a flat section of bar and then be able to remove afterwards
Mr Whippy
posted on 27/2/09 at 10:40 AM Reply With Quote
I believe the hole has to be a different shape...
adithorp
posted on 27/2/09 at 10:56 AM Reply With Quote
Internal radius rules apply. Use edge trim on the shaft of the lever and radius the ends of your T bar.
adrian
http://jpsc.org.uk/forum/
Richard Quinn
posted on 27/2/09 at 11:35 AM Reply With Quote
If it's for the SVA test then why not just take the lever off for the test and put it back in after you've passed?
spdpug98
posted on 27/2/09 at 05:12 PM Reply With Quote
I was going to leave it off but my mate who is doing all the little metal work bits was already planning on making it all rounded, so will possibly fit it for SVA
Thanks for the advice
